alternator
92civic21
Posted
can i get a alternator that has a higher amp output that bults right on to the car? and do u know where i can get one? i saw some 170 amp ones on ebay but idk if they will bult right on.
Posted
yes you can. the difference is the amount of copper wound around the armature. its a good idea as well if you plan on runnin high power draw amps. you can get alt. like we speak of that will bolt right up yes.
Posted
If you've checked Autozone go check a Speed Shop or maybe you call them Tuner shops, that sells nothing but aftermarket parts i know that they will have a high output alternator...:thumbsup:
