NEED HEL REWIRING AND VTEC PROBLEM LET ME KNOW ASAP!!!
trickz
Posted
listen i got a problem my speedometer aint workin, the heater wont blow to the feet or window, the cig lighter dont work , and my vtec wont kick in it has a check engine light on let me know if anyone can do it 917-529-3074 or bleep me 183*135*12756 or 384-1003 my name is eddie i need help asap or give me some advice..
Posted
what kind of engine are you running in your car? do you have the right ecu? usually vtec doesnt kick in because the oil is low, check your oil. if you have an older car then maybe its time to replace the whole ac console. lighter might not work cause of a faulty fuse. check your fuses.
