ArtyMillz Posted February 27, 2006 Posted February 27, 2006 i wanna turbo my motor when i have it installed but i had a couple questions i was wondering if some1 can awnser...can i just add the turbo on the motor with the stock compression or do i need to do work on it first
SolLesHonda Posted February 27, 2006 Posted February 27, 2006 You don't need to lower the compression, or "work" on it, but I wouldn't run stock internals on much boost. How much boost are you looking for ? What kind of numbers are you looking for ?
CleanGSR Posted February 27, 2006 Posted February 27, 2006 You can run 7-8 psi fine without a decent setup. Anymore than that and you'll want to lower your compression or build your motor.
xxscaxx Posted February 27, 2006 Posted February 27, 2006 i only ran 6psi on mine. then again, i wasnt tuned, so i wanted to play it safe.
SolLesHonda Posted February 27, 2006 Posted February 27, 2006 Loser. Ha, just kidding. Think about how fast it would have been on 14 psi, tuned ... Probably stay or beat the STI stock.
blackdelsol Posted February 27, 2006 Posted February 27, 2006 awd launches much better. fwd = slippage.
SexyH22 Posted February 27, 2006 Posted February 27, 2006 get arp mains and headstuds, and a cometic head gasket. and injectors. should be good for more than 10 with a good tune.
