How is this Amp Kit? Is it a good one
Verbal Killa
Posted
Should i buy it? runnin a kenwood 1800w 9152d amp. wit 2 15" kicker comp vr's 2005.
Audiopipe 4 Gauge Amplifier Installation Kit
1600 Watts to 2100 Watts
Posted
no that kit is a1 , just what you need. 4 gauge is good for you no need to go any bigger. it says 1800 watt , that means its 900 nominal , 4 is plenty. what resistance are your subs? 4 or 8 ohm?
Posted
15" subwoofer with high-strength steel basket
Polymineral cone with double-stitched foam surround
Power Handling Watts, Peak (RMS) - 500 (250)
Sensitivity [sPLo], dB @ 1W, 1m - 90.2
Effective Frequency Range, Hz - 25-500
Mounting Depth, in (cm) - 7 3/8 (18.7)
Hole Cut-Out Diameter, in (cm) - 13 7/8 (35.2)
Equivalent Volume [Vas], ft3 (L) - 9.61 (272.33)
Net Displacement, in3 (cc) - 198.7 (3256.8)
Moving Mass [Mms], oz (g) - 7.38 (209.31)
Magnet Weight, oz (kg) - 75 (2.13)
Mono channel Power Amplifier with Dual Mono Drive Function
RMS Power: 500W x 1 @ 4 ohms
RMS Power: 900W x 1 @ 2 ohms
RMS Power: 900W x 1 at 1 ohms
RMS Power: 900W x 2 at 4 ohms (Dual Mono Drive)
Aluminium Die-casting Heat Sink
Detachable Aluminium Dress Plate & Top Panel Control
Dual Mono Drive (Bridged Connections of KAC-9152D x 2)
Gold Plated Input/Output Terminals
Single Side Exposure of Terminals for Multi Installation
Posted
nice...kickers hit hard
i hope you like rap, b/c they will detory the sound quality of any other style of music, not like it matters if rap sounds like shiat.
Posted
i, personally would go with 2 gauge, but 4 will work fine. don't worry about it though, you should be okay.
Posted
buy the godforsaken 2 gauge kit then, $15 is pocket change nowadays
Posted
2 gauge isnt needed like at all but whatever turns your cranks. yeah its only 15 bucks in the diff but its also 15 bucks that dont have to be spent. ive wired in over a dozen full stereo installs, and never have i used 2 gauge. its simply overkill.
Posted
yeah i've never used 2awg either.4 or 8
agreed, unless you are doing some serious output you wont need 2awg. and from experience i wouldn't wire off name brands because of the quality. it may say 4 awg but it might only be 8 awg with extra insulation.
Posted
i've used 2 gauge wire plenty of times (5 or 6), and he's going for a high power application, over 2000 watts, in that case i would use 2 gauge wire, just my opinion though. 4 gauge will work, just me personally would use 2 gauge.
Posted
if your talkin 2000 watts nominal power not peak than yeah i can see understand you usin 2g in fact if i was installin a system that was runnin 2000watts nominal i would recommend 0gauge. but 1000 watts nominal is fuk all for 4g to handle.
Posted
He said 1800 watts. He never specified if it was peak or nominal. I guess that's what makes this into a mis-understanding. And I'm too lazy to look up the amp and see if it's 1800 rms or peak.
Posted
also if you are pushing that much power you might want to upgrade your alternator and battery. optima yellow tops are nice. but any deep cycle battery will do. i've seen guys put marine batteries into their cars. with that much power output you will drain your stock battery quickly because your alternator can't pump out enough juice.:thumbsup:
