95whtcivichatch Posted February 24, 2006 Posted February 24, 2006 ive got a stock 95 civic hatch VX crapty motor i know. i put a short ram intake on it, for craps n giggles, well just recently within 24 hours, my v-tec e does not kick in it at all...it will not red line, when the RPMs get to 5500 it like "coughs"...whats the deal...and motor swaps...if i could get a GSR motor, heads blown, everything else is fine for 400 should i do it and re-do the top part? or should i put a prelude motor in my car for bigger displacement??? i really appreciate any help any of yall can give me...thanks a lot!
stetypeR Posted February 24, 2006 Posted February 24, 2006 Could be somthing as simple as your oil level being to low id check that for a start.
95whtcivichatch Posted February 24, 2006 Author Posted February 24, 2006 when i got home from work, had to drive home ya know...i lightly tapped on the "vtec" thinkin its possibly going out, or something, like youd lightly tap on the starter, and drove it again, and its still doin the same thing, my oil is fine, i checked that...
xalexjx@yahoo.com Posted February 24, 2006 Posted February 24, 2006 check your ecu to make sure no wires cam unplugged, also check the engine bay for unplugged wires,
95whtcivichatch Posted February 24, 2006 Author Posted February 24, 2006 where exactly in my engine bay is my ecu?
xalexjx@yahoo.com Posted February 24, 2006 Posted February 24, 2006 engine bay is where the engine is, ecu under passenger floormat, just look for a wire that looks unplugged,,you may have accidently unplugged one when you were putting in the intake or something also your engine probly could use a tune up including the fuel filter and so forth, but if you want to scrap it here ya go, http://www.hondaforums.com/index.php?showtopic=13646 5th Generation 1. B16A2/3: Completely bolt-in Swap, VTEC needs to be wired, SIR II, Hasport shift linkage. Del Sol VTEC for the del sol 2. B18B: Completely bolt-in swap, SIR II, Hasport shift linkage. Del Sol VTEC for the del sol 3. B17A: Completely bolt-in swap, cable-hydro transmission kit(not recommended) or hydraulic b-series transmission, VTEC needs to be wired. 4. B18C1: Completely bolt-in swap, VTEC needs to be wired. 5. B18C5: Completely bolt-in swap, OBD conversion, VTEC needs to be wired. 6. B16B: Completely bolt-in swap, OBD conversion, VTEC needs to be wired. 7. H22A: Mount kit required, Hasport shift linkage, VTEC needs to be wired. 8. B16A: Not recommended! Too much work, more costly compared to B16A2/3's. 9. D16Z6: Completely bolt in, VTEC needs to be wired. 10. D16Y8: Completely bolt in, VTEC needs to be wired. edit: also some of these need diff axles heres the specs on the engines: ZC: Price: 750.00 1395cc (1.6L) DOHC or SOHC VTEC 130hp/91tr 10.9 Compressions Ratio Cable Tranny 130hp B16A1: Price: 1350.00 1595cc (1.6L) DOHC VTEC 160hp/112tr 10.2 Compression Ratio Cable Transmission 160 HP B16A2: Price: 2350.00 1595cc (1.6L) DOHC VTEC 170hp/112tr 10.4:1 Compression Ratio Hydraulic Transmission 170 HP you want the b16a2, its an easy affordable swap that will give you a good base for boost B16B: Price: 4600.00 B18B(LS): Price: about 500 1500cc (1.8L) DOHC 150hp/100trq 11.5 Compression Ratio Cable Tranny B18C1(GSR): Price: 3300.00 1797cc (1.8L) DOHC VTEC 180hp/129trq 10.6:1 Compression Ratio Hydraulic Transmission 180HP B18C5(ITR): Price: 4800.00 1797cc (1.8L) DOHC VTEC 197hp/134trq 11:1 Compression Ratio Hydraulic LSD Transmission 190 HP B20: thin cylinder walls, not the best to boost Price: 900.00 H22A: Price: 2500.00 2.157cc (2.2L) DOHC VTEC 200hp/161trq 10.6 Compression Ratio Hydraulic Transmission 200HP H22A Type S: Price: 4500.00 JDM F20B: Price: 4000.00 200hp/145 trq K20: Price: around 10k when the whole swap is done 200 hp 158 trq I-VTEC
SolLesHonda Posted February 24, 2006 Posted February 24, 2006 I'd say good post, but you typed none of that. And you didn't even acknowledge where you stold that info from. That's wrong, and I'd be pissed if I had wrote all of that, and you just stole it without at least an honorable mention of the site or his name. Ass.
CleanGSR Posted February 24, 2006 Posted February 24, 2006 No kidding. THat's called plagiarism and it's illegal.
95whtcivichatch Posted February 25, 2006 Author Posted February 25, 2006 ok, so i went to my boys house, and he told me that the V-TEC E is just most likely dirty, so i think tomorrow sometime, i am going to take it off, and clean it, and check it out, also he said he has a V-TEC from a B16 and he said i can put it on my car...TRUE or FALSE? and what would i need to do to do that, if anything???
xalexjx@yahoo.com Posted February 25, 2006 Posted February 25, 2006 did i claim credit to any of that, NO...its not plagarism, false, what exactly are you talking about? the actual vtec cylonoid..d series and b series engines are totaly diff and the parts wil most likly not match
95whtcivichatch Posted February 25, 2006 Author Posted February 25, 2006 yes, the actual vtec cylonoid needs to be cleaned, i didnt see any unplugged wires, when i rev it from the engine, it sounds fine, but when im driving it, it doesnt kick in at all anymore...
adamEj6 Posted February 25, 2006 Posted February 25, 2006 not to stir anything up, but why do you guys get so pissed about if he copy and pasted a big thing and didnt say where he got it from and also why do you correct like every spelling and punctual marks?
SolLesHonda Posted February 25, 2006 Posted February 25, 2006 because we can. +1 ... and don't stir anything up. Just don't get into it.
CleanGSR Posted February 25, 2006 Posted February 25, 2006 I know if I had spent the time to write something out that took a lot of work and then someone posted it somewhere without giving me credit, I'd be pissed. That's why I said something.
cranny Posted February 25, 2006 Posted February 25, 2006 B16 head dont fit your engine but if you can get a whole engine tranny and ecu id put the whole B16 in my car. vtec solenoid not kickin in vtec is one thing but the car not red lining on full throttle? thats another thing altogether. your cars vtec not engaging is nothin to do with the car not reachin its redline under full throttle.
not_all_motor_civic94 Posted September 8, 2006 Posted September 8, 2006 my 95 civic done the same thing vtec would not work and it would go to 6500 and stop just like his is doin....this guy i know that works at the dealer ship said if vtec dont kick in its messin up the computers timin and i took if off and replaced it with another cylonoid i had it worked and ran fine!
