EG DOOR wiring.. need a tiny bit of help!
mountaindewguy
Posted
ok basically my passenger door has had a few wires replaced, and i need to rewire some stuff to get my electric window working on that side (i think some wires under the dash are broke or cut) anyways, simple question, what colors are the 2 wires going into the window motor on the passengers side? thanks!
Posted
man im not sure dude , just take the door panel off and find out whats power and ground for the windows and run them accordingly. ground is almost always black. so ground the ground and run 12v to the other wires till you find what makes windows work. when you find what wires are what make sure you run acc. power to them not constant.
Posted
i think its white green and red...im not sure, i dont have the luxury of power windows but as what i can remeber yea....do a google search for it
