91 dx with LS sWAP....
lilSikSoL
Posted
how you all doing...lol...ok i just got my self a 90 crx dx with a 89 ls swap the wireharnes lo0ks all fV(k up...the last owner did the 2 injectors to 4 injecters swap.. but it dosent convinse me wen i got the car he told me all it needed was the timebelt to be done...i did it 2day an it still dosent go on then wen i pull the oil dip stik i could smell gas in it..(y)? the pump is good the gas filter is good thers spark too..is ther like a test i can do to see if my injecters work....?i noe this sounds all random.. but im just about 2 junk the whole car im getting pist ...u know what if thers some one in queens that noes about wireng ls's drop me a number(( lilhaifdead@yahoo.com )) an all pay you 2 doo it for me..but for now al settle for a page that explains how to do it.....thanx an sorry for all the bad spelling....just had a long day with the crx...
Posted
2 injector to 4 injector swap? if you mean splicing a 2 wire harness to go to 4 injectors thats most likely your prolem. sounds like you need the proper harness for your engine bay and maybe an ecu i dont know. if he didnt change the harness he didnt change the ecu. you got a good setup waitin for you though , you should ask bigbirdsucks hes got an lsvtec setup could prolly help you more.
Posted
mine is cr-vtec actually, but same concept.
you're talking about a DOHC non-VTEC D series motor, right? if so, the '89 integra distributor has more sensors than a SOHC distributor. there's a certian wire you have to redo, but I can't remember what exactly needs to be done. if you've conquered the distributor problem and it still won't start, look at what ECU you're running. it'll have to be an '89 integra ECU. hope this helps a little.
Posted
im talking about the b18a1 motor ..an i think they did what cranny said splicing a 2 wire harness to go to 4 injectors idk ima see what i can do... any of u guys from ny,,,? http://www.hondaclassifieds.com/default.as...tail&adid=78047
Posted
ya, im from up state ny.
damm thas far i need some one near queens....all pay for someone ccome do the wires 4 me.....
Posted
there ya go BBS free vacation on him , hahaha.:p ever been to NY?
hahaha
