b16civichatch Posted February 11, 2006 Share Posted February 11, 2006 so i need a knock sensor for my ls VTEC b16 motor. does anyone know of websites or where to go to get one? can i order one at like the local car parts store? Link to comment Share on other sites More sharing options...
mountaindewguy Posted February 11, 2006 Share Posted February 11, 2006 what setup are you running? you can get an ECU chipped with a basemap and programmed to function without one from phearable.net good ECU's there, and they have conversion harnesses if needed, much worth the money! Link to comment Share on other sites More sharing options...
b16civichatch Posted February 11, 2006 Author Share Posted February 11, 2006 what setup are you running? you can get an ECU chipped with a basemap and programmed to function without one from phearable.netgood ECU's there, and they have conversion harnesses if needed, much worth the money! well i just got the car. but it has a b16 motor swap with a gsr tranny and im not sure what ecu it has. i believe its the the p72. Link to comment Share on other sites More sharing options...
b16civichatch Posted February 11, 2006 Author Share Posted February 11, 2006 so what all will i need for that? Link to comment Share on other sites More sharing options...
mountaindewguy Posted February 11, 2006 Share Posted February 11, 2006 does it have the lsvtec, or the b16? cause you said lsvtec then you said b16 motor swap. ? Link to comment Share on other sites More sharing options...
Humphries Posted February 11, 2006 Share Posted February 11, 2006 i dont see him saying lsvtec.. anywhere in his posts. you can find a p72 ECU on Ebay.com Link to comment Share on other sites More sharing options...
mountaindewguy Posted February 11, 2006 Share Posted February 11, 2006 so i need a knock sensor for my ls VTEC b16 motor. first post. Link to comment Share on other sites More sharing options...
