Am15h Posted February 6, 2006 Share Posted February 6, 2006 Hi people,. Ive got a problem with my Honda coupe VTi '99, i get a power slump in low revs, even at gear changes, No one seems to know whats wrong with it, but at higher revs the cars fine (I cant hit 140mph easly). ive changes the Leads, filter, plugs let me know if any of you have had the same problems or know whats wrong, Thanks Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted February 6, 2006 Share Posted February 6, 2006 try changing the fuel filter Link to comment Share on other sites More sharing options...
ap1drvr Posted February 6, 2006 Share Posted February 6, 2006 +1 with fuel filter, also check to make sure your timing is where it needs to be. Link to comment Share on other sites More sharing options...
Am15h Posted February 7, 2006 Author Share Posted February 7, 2006 Yeah thanks, i changed the Fuel Filter today as it happens, runs better, but i still get a little lag while changing gears, i heard the VTIs retune its self, its just a bit gutless really, lol, running out of parts to change Link to comment Share on other sites More sharing options...
ap1drvr Posted February 7, 2006 Share Posted February 7, 2006 Check your timing & valve lash. Link to comment Share on other sites More sharing options...
Am15h Posted February 7, 2006 Author Share Posted February 7, 2006 How can you check the timing and whats the Valve Hash? Link to comment Share on other sites More sharing options...
ap1drvr Posted February 7, 2006 Share Posted February 7, 2006 You'll need a timing light to check. Valve lash is the gap between the rocker arm & the valve. If it's too large the valve doesn't open as quickly or as far as it should. Link to comment Share on other sites More sharing options...
Am15h Posted February 7, 2006 Author Share Posted February 7, 2006 You'll need a timing light to check. Valve lash is the gap between the rocker arm & the valve. If it's too large the valve doesn't open as quickly or as far as it should. its got variable valve timing and i think i had the the timing checked at honda and they said it was perfect, Link to comment Share on other sites More sharing options...
ap1drvr Posted February 7, 2006 Share Posted February 7, 2006 variable valve timing i.e. VTEC only comes into effect around or after 5600 rpm, I was referring to timing at idle, if it was within spec then that's ruled out. Try valve lash next, that would be adjusted at the same time. Unless the clearance is way out of spec it wouldn't cause a huge hesitation. Did you check the cap & rotor when changing plugs/wires.... if this is your first Honda, they aren't known for their low RPM power, or lack there of. Link to comment Share on other sites More sharing options...
Am15h Posted February 8, 2006 Author Share Posted February 8, 2006 variable valve timing i.e. VTEC only comes into effect around or after 5600 rpm, I was referring to timing at idle, if it was within spec then that's ruled out. Try valve lash next, that would be adjusted at the same time. Unless the clearance is way out of spec it wouldn't cause a huge hesitation. Did you check the cap & rotor when changing plugs/wires.... if this is your first Honda, they aren't known for their low RPM power, or lack there of. yeah i had the clearence done by honda, and i cleared out the cap and it did run better. You think it could be the ECU? Link to comment Share on other sites More sharing options...
ap1drvr Posted February 8, 2006 Share Posted February 8, 2006 Doubtful, you'd have other problems also if the ECU was going bad, how many miles are on it? Maybe try pulling some of the slack out of the throttle cable & see what it does. Link to comment Share on other sites More sharing options...
Am15h Posted February 8, 2006 Author Share Posted February 8, 2006 Doubtful, you'd have other problems also if the ECU was going bad, how many miles are on it? Maybe try pulling some of the slack out of the throttle cable & see what it does. its done about 76k miles, the only way i can describe the problem is that it feels like the cars been draged back after a gear change, ill try the throttle cable n see what happens i suppose Link to comment Share on other sites More sharing options...
ap1drvr Posted February 8, 2006 Share Posted February 8, 2006 That's all I can think of right now. Link to comment Share on other sites More sharing options...
Am15h Posted February 8, 2006 Author Share Posted February 8, 2006 That's all I can think of right now. Well thanks mate, ill give it ago n see what happens Link to comment Share on other sites More sharing options...
