AAAuthority138 Posted February 2, 2006 Share Posted February 2, 2006 Is this everything I need to put a B18C1 into my 95 civic LX? Will it be an easy swap? Or do you think I should go with the B16? •Motor •Transmission 5SPD Manual •Engine Wiring Harness •All required Cables •ECU •Distributor •Throttle Body •Injectors •Fuel Rail •Intake Manifold •Exhaust Manifold •Alternator •A/C •Power Steering Pump •All Brackets and Sensors •Intermediate Mid Shaft Link to comment Share on other sites More sharing options...
