JDM_Hamster Posted April 17, 2006 Share Posted April 17, 2006 well too bad because you will... So live with it... Link to comment Share on other sites More sharing options...
catawalks Posted May 15, 2006 Share Posted May 15, 2006 not to bring up an old thread but i'm still confused as to how cambers work and exactly what they do. I'm assuming that camber kits correct wheel angle? but if you get your wheel aligned how does that still affect things? Link to comment Share on other sites More sharing options...
CleanGSR Posted May 16, 2006 Share Posted May 16, 2006 I'll try and explain it best I can. Camber is the angle of the wheel in perspective to the car. If the top of the wheel leans in, that's negative camber. If the top leans out that's posititve camber. When you lower your car it makes your car have negative camber, so a camber kit is needed. Toe and Caster are also important and deal with the angle of the shock, if the wheel is aligned in the wheel well, etc.... The camber kit I installed fixed my camber but messed up the caster and toe a little. When I had it aligned they put all of it back to spec. Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 16, 2006 Share Posted May 16, 2006 You know what I noticed? My buddy's stock 2006 Civic SI has pretty bad negative camber in the rear. Weird. Link to comment Share on other sites More sharing options...
catawalks Posted May 16, 2006 Share Posted May 16, 2006 thanks guys...what would you say? spend the couple hundred on a camber kit for this or just try to get it aligned as it is...i wanna get new lca's front and rear and uca's for the front...what do you guys think? Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 16, 2006 Share Posted May 16, 2006 I think you should take care of that rust first. Honestly. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted May 16, 2006 Share Posted May 16, 2006 Yeah same here, rust is like cancer, there is no cure other than cutting it out and it will only spread if you dont. Link to comment Share on other sites More sharing options...
catawalks Posted May 17, 2006 Share Posted May 17, 2006 yeah...i just started putting money away for that a little while ago...but I have to go get a direct quote and crap....if only i knew people like solles did...i don't wanna have to pay 3k for that....i could most likely sand a lot of it off myself and bondo over it to smooth the lines but i'm way too lazy for it... Link to comment Share on other sites More sharing options...
