shifter problems
acourt
2001 automatic ,it takes a extreme amount of force to push in the button in on the shifter,once pushed in it will go in to gears ,so i taped the button in place in order to shift into gears but there must be some kind of adjustment as the plastic piece under the handle does not appear to be broken,shop said there is an adjustment in the brakes to solve this problem,what i want to know is how to make this adjustment. thanks
