back seats
Speedy88
  • Replies 65
  • Created
  • Last Reply
  • 1 month later...
noit doesnt, itseasy, on 92-95civics you pull up the bottom bench part of the seat, and removve the metal plate unscrew the bolts and the cap has the pump connected to it, so when you pull the cap off everything comes with it, but it will make your car smell like gas for a while
it is under the back seat, under the seat there is an egg shaped plate, take that off, its the top of the gas tank. theres another cover with like 6 bolts on it, undo those, that circular cover comes up with the pump attached to it
it is very easy just unbolt the bottom and then the top and if you want unbolt the outer along the roof and even more weight red. take out your power steering and you ac.
I have put the s 2000 seats into my del sol it was not easy because the holes of the rails are not the same
