oil in my civic
93CivicB18man
Posted
I was wondering one of my buddies told me that my b18 engine would leek oil like crazy and i was just wondering if this is true and is there any way that i could get this to stop if this is true??
plz help!!
Posted
alright my buddy was like i will tell you now when you buy the b18 it is going to leek oil really bad he said even though there will be nothing wrong with it. It is going to leek really bad and i was thinking the only way that is would leek would be that if there was something wrong with it!
thx for the info
Posted
are you supposed to be buying the engine from your friend? or a friend of the friend?
Posted
no im buying the car and it has the b18 in it but if that was the case then i prob will not get it then
you can buy a cam seal for about $25 or less that should stop the problem
Posted
where it leak from?
rear main seal?
oil pan gasket?
engine drain plug?
go check those.....
:ph34r:
