What is a ZC Engine?
Cdizzle_996
Posted
I had a add posted in my local classifieds for a Engine for my 1991 Civic Hatch. I just recieve a call for a ZC engine, but i dont know what it is. Ive heard of them, but i dont know specs, and such. Any info u have would be greatly appriciated
Posted
125hp @ 6600rpm
106tq @ 5200rpm
and a direct bolt in for your car too, no modification except the wiring for the vtec and that can be done in 15 minutes
Posted
125hp @ 6600rpm
106tq @ 5200rpm
silly noob
the "hardest part" would be the dpfi to mpfi conversion if you have a DX/Std. model
reference pages:
http://hybrid2.honda-perf.org/tech/zcinfo.html
http://thenew.gamesbbs.com/~dmoore/zc.htm
Posted
125hp @ 6600rpm
106tq @ 5200rpm
Is that the single cam vtec one?
I have a Dual Cam ZC, and it was a direct drop in. We had to Jimmy-rig the distribtor(sp?) to work, and we removed the TEC device on the exhaust cam. That was it.
Now, if you have a STD/DX, you'll have to do the dual-point coversion. You'll be happy with that for a while if you do that, and it's a little cheaper than a ZC swap. Then later on down the road, you can do the ZC swap.
If possible, try to get the ZC tranny too. Stay away from the USDM "ZC", D16a1 I think. It's trash, and don't use the ecu from that motor either. It sucks.
Posted
d16a8/9 is equivalent
