Rear quarter panels
tjm58705
Posted
I have a 94 ex coupe with a damaged driver rear quartel panel. I wan to fix this but i am not sure what route i should take. It is dented pretty bad. The only good part about this is that my buddy has the exact color car with front end damage. can the whole peice be unbolted some how???? Please help..Thx
Posted
Are they definitely just welded on? If so if i drill out the spot welds do i have to re weld it back on or does it have a double wall that i may be able to drill and tap to bolt it back up.
