speedometer quits working.
maninkingcounty
I have a "95 Civic EX. Sometimes the speedometer quits working and shows 0 mph while the car is moving. When this happens, the odometer quits working, as well. The tachometer continues to work, though. After a while, it starts to work again. Is this problem caused by the speedometer itself, the sensor, or the wiring between them?
Invest in a multimeter.
check your wiring take the multimeter abd ohm out the wiring, put the probes to each side of the wire, most wiring .5ohms is about normal less then 1 is good, i'm not sure bout car wiring but it should be about the same.
more then 1ohm and u have a bad connection, or loose.
