Speedy88 Posted August 21, 2005 Posted August 21, 2005 hey i have a 91 civic and its leakin oil from the top of the intake manifold just wondering if its that or if theres some where else it would be comin from
The nine two Posted August 21, 2005 Posted August 21, 2005 Don't think it's from the Intake manifold, if it was, that would be crazy, it's most likely coming from the back of your valve cover and then on to the top of your intake manifold,check that out, are you losing mad oil, or is it just dirty?
eric94bubble Posted August 21, 2005 Posted August 21, 2005 clean your motor first then begin your investigation.more than likely its your valve cover
Speedy88 Posted August 21, 2005 Author Posted August 21, 2005 is there any other spots it could be leaking from? and how hard is it to change a fuel pump
Speedy88 Posted August 21, 2005 Author Posted August 21, 2005 i put a new gasket on the valve cover and its still leakin around the back of the head im confused of were it could be comin from? someone help
Speedy88 Posted August 22, 2005 Author Posted August 22, 2005 i found the problem. there used to be an oil cooler on it so took it off
