SolLesHonda Posted January 31, 2006 Share Posted January 31, 2006 Ok well it has been a while, figured I'd update you all. I was building my CRVTEC and I ran into some problems. I had been sent parts that were not the ones I had ordered, so I was going through hassles with companies and so forth. They finally sent me my money back, and I have been doing some thinking. I have sold the b20 block I had and made more than I had bought it for. I have decided I want to play aroung with turbo, so I ditched the b20. From sunrisejdmmotors, My local tuner got me the d16z6 complete swap for 500 dollars shipped, and I have done a couple mods to that ... Here are the mods so far : Ported and polished head Darton sleeved block Eagle H rods ARP studs CP pistons ACL bearings Crower springs/retainers Rocket motorsports valves crower stage 1 cam hondata s200 with boost msd digital 6 ignition msd wires aem fuel rail/FPR/fuel filter walbro in tank pump garrett t3/t04e .57 a/r turbo west coast turbo stage 3 FMIC west coast turbo charge piping custom manifold with external wastegate tial 38mm wastegate hks ssqv BOV 550 cc injectors aem adjustable cam gear 3" turbo back exhaust, no cat, tanabe hyper medallion muffler getting tuned as soon as all parts are finished being put on ... Going to run around 11 psi for daily use, but is def. capable of 20+ psi. At 25 psi should break 350-400 whp. What do you guys think ? ? ? Link to comment Share on other sites More sharing options...
Batman Posted January 31, 2006 Share Posted January 31, 2006 I dont know much about imports yet bet it sound good. :smoking: Link to comment Share on other sites More sharing options...
SolLesHonda Posted January 31, 2006 Author Share Posted January 31, 2006 Haha, thanks ... Depending on the tune and the boost psi I should run 12's on street tires. I think if I had some more tranny work and slicks and high boost, I could run in 11's. Link to comment Share on other sites More sharing options...
Batman Posted January 31, 2006 Share Posted January 31, 2006 Well just think you can drive yours right now but I have to push mine :( Link to comment Share on other sites More sharing options...
CleanGSR Posted January 31, 2006 Share Posted January 31, 2006 I'm just curious as to why you are only going to run 11 psi daily on that setup. 11 psi will probably get you around 270whp on that motor. 14 would put you well over 300whp and would be safe daily driven. I doubt you'll run in the 12's on 11psi but that just me. As for the setup, I think it looks really good except for the psi stuff I mentioned. Link to comment Share on other sites More sharing options...
cranny Posted January 31, 2006 Share Posted January 31, 2006 i think your hoping for more power than your gonna get but sounds like a fun setup. Link to comment Share on other sites More sharing options...
CleanGSR Posted January 31, 2006 Share Posted January 31, 2006 That's an impossible. An engine won't even run without internals. Link to comment Share on other sites More sharing options...
CleanGSR Posted January 31, 2006 Share Posted January 31, 2006 I'm not trying to start a fight again, but there is no way a stock internal B series can hold that much power. A lot of built B's would break with 500whp let alone a stock. The pistons, rods, etc. just couldn't handle the power. Link to comment Share on other sites More sharing options...
SolLesHonda Posted January 31, 2006 Author Share Posted January 31, 2006 It was a one time thing. The engine blew up directly after that dyno pull. B16, you think I could run 14psi daily driven ? 13 psi should get me in the low to mid 13's. 20+ psi without major traction issues should get me 12's. Link to comment Share on other sites More sharing options...
CleanGSR Posted January 31, 2006 Share Posted January 31, 2006 Considering that you are fully building this motor, you should be able to easily run 14psi daily. A lot run 9-10 psi daily on stock D16z6, so 14 on a fully built should be like cake. If I fully built my B16, I would run 14 daily, SexyH22 is going to run 14 on his H22. I can't think of any reason it would be any different on a built Z6. Link to comment Share on other sites More sharing options...
SiR_Richie Posted January 31, 2006 Share Posted January 31, 2006 yeah, the magazine was hondatunning, but he had internals, it was almost a full mugen/spoon setup here is the link... http://www.solsociety.com/forum/index.php?showuser=1554 or http://forum.crxownersclub.com/index.php?showtopic=10 here are his mods: b]Interior[/b] -MUGEN Sports Pedal Set 5MT (46545-XG5-K2S0) -MUGEN Shift Knob 5MT Silver (54102-XG4-K0S0-S) -MUGEN FG360 Sterring Wheel (53110-SW7-K0S0) -MUGEN Steering Wheel Hub (53130-XG5-K1S0) -MUGEN Reserve Tank Cover (90000-YZ7-0054) -JDM EG2 CR-X Del Sol SiR Map Lights (34230-SR2-013ZA / 34235-SR2-013ZA) -JDM EG2 CR-X Del Sol SiR Sun Visors (83280-SR2-J01 ZA / 83230-SR2-J11 ZA) -JDM EG2 CR-X Del Sol SiR Gathers Rear Speaker Grills -JDM Integra Type R Recaro SRD Seats Black Suede w/ Red Stitching -NRG Steering Wheel Quick Release Exterior -MUGEN Rear Wing CR-X Del Sol EG2 -MUGEN Front Bumper CR-X Del Sol EG2 -JDM EG2 CR-X Del Sol SiR Lower Fog Lamps w/switch (08V31-SR2-600) -JDM EG2 CR-X Del Sol SiR Headlights (33100-SR2-J03) -JDM EG2 CR-X Del Sol SiR Taillights -JDM EG2 CR-X Del Sol SiR License Plate Filler Panels -JDM EG2 CR-X Del Sol SiR Side Marking Lamps (33800-SR3-J01 / 33850-SR3-J01) -JDM EG2 CR-X Del Sol SiR Rear Badge (CR-X Del Sol - 75765-SR2-J02ZE) -JDM EG2 CR-X Del Sol SiR Rear Badge (SiR - 75723-SR2-J12ZE) -JDM EG2 CR-X Del Sol SiR Side Decals (DOHC - 75772-SR2-003ZE) -JDM EG2 CR-X Del Sol SiR Side Decals (VTEC - 75774-SR2-003ZE) -JDM Rear Glass Parking Decal -JDM Front Glass Parking Decal -JDM Techlogex "Boost is Better" Decal Engine -FWHP 269 @ .6 Bar (XS Engineering) -FWTQ 183 @ .6 Bar (XS Engineering) -USDM B16A3 -TODA High Power Timing Belt Del Sol B16A (18.TD.TBB16A) -MUGEN Fan Switch Del Sol 1994-1997 (37760-XK5-00N0) -MUGEN Formula Head Cover Del Sol 1994-1997 VTEC (12310-XG7-K1S0) -MUGEN Oil Filler Cap (15610-XG7-K0S0) -MUGEN Thermostat Del Sol 1994-1997 VTEC (19301-XGER-0000) -Spoon Sports Magnetic Drain Bolt Set (90009-000) -JDM Honda Integra Type R Intake Cam -JDM Honda Integra Type R Exhaust Cam -JDM Honda Integra Type R Valvetrain -JDM GReddy High Flow Injectors 720cc (13500072) -JDM HKS SSQV Blow Off Valve w/ Steel Flange -JDM Cusco Oil Catch Can -Skunk II Adjustable Cam Gears -Koyo Aluminum Radiator -Odessey Slim Battery -MSD Ignition Wires Black/Gray -Spark Racing Stainless Turbo Manifold -Garrett T3-T4 Hybrid Turbo -Tial 38mm Wastegate -XS GTR Power Core Intercooler -Custom Intercooler Piping -Custom Downpipe -Walbro 255lph Fuel Pump (gss 342/400-846 install kit) -B&M Fuel Pressure Regulator -B&M Fuel Pressure Guage -Samco Radiator Hose Kit Exhaust -Maganaflow Muffler -JDM JGT500 Espiler B Pipe Drivetrain -Competition Clutch Stage 4 Strip Series 1620 Clutch Kit with Light Weight Steel Flywheel Suspension -MUGEN Front Tower Bar Civic 1992-2000 (74300-XGER-K1S0) -MUGEN Rear Tower Bar Civic 1992-2000 (74380-XGER-K1S0) -Spoon Sports Rear Lower Tie Bar (74351-EGA-000) -Ingalls Front Camber Kit -JDM Tein Super Street Coilovers w/Pillowball Mounts Wheels/Tires -MUGEN RNR Black w/Red Lip Wheels (42700-RNRU-1 565BL) For Sale -MUGEN Wheel Nut & Lock Set (08181-M07-K0S0-BL) -Toyo Proxes FZ4 Tires 205/50/15 Brakes -PowerStop Brake Rotors -Axxis Brake Pads ICE -Clarion DV925 Head Unit -JL Stealthbox Honda Del Sol -Kicker CVR8 Subwoofer x2 -Rockford Fosgate P3002 Amplifier -JDM EG2 CR-X Del Sol SiR Gathers Speaker System Engine Management/Electronic -JDM Defi DF Control Unit II (DF05001) -JDM Defi DF 60 Turbo BF (DF04301) -JDM A'pex Power FC (414-H003) Accomplishments: 1st Place "Baddest Del Sol" - Importfest San Diego 2003 "Best Del Sol" - Team Sol Cal Vegas Invasion IV "Best Interior" - Team Sol Cal Vegas Invasion IV 1st Place "CRX/Del Sol Class" - Extreme Autofest San Diego 2004 3rd Place "Honda Class" - Showoff Classic Chinatown 2005 Magazine Coverage: Link to comment Share on other sites More sharing options...
blackdelsol Posted February 1, 2006 Share Posted February 1, 2006 wow I cant wait to see some pics. I'm in the process of pretty much the same thing. a few different parts I'm looking at though. spearco makes an intercooler perfectly sized for my grill, etc... how much has it cost so far and were did you get the money Link to comment Share on other sites More sharing options...
airjordan223 Posted February 1, 2006 Share Posted February 1, 2006 yeah, the magazine was hondatunning, but he had internals, it was almost a full mugen/spoon setuphere is the link... http://www.solsociety.com/forum/index.php?showuser=1554 or http://forum.crxownersclub.com/index.php?showtopic=10 here are his mods: b]Interior[/b] -MUGEN Sports Pedal Set 5MT (46545-XG5-K2S0) -MUGEN Shift Knob 5MT Silver (54102-XG4-K0S0-S) -MUGEN FG360 Sterring Wheel (53110-SW7-K0S0) -MUGEN Steering Wheel Hub (53130-XG5-K1S0) -MUGEN Reserve Tank Cover (90000-YZ7-0054) -JDM EG2 CR-X Del Sol SiR Map Lights (34230-SR2-013ZA / 34235-SR2-013ZA) -JDM EG2 CR-X Del Sol SiR Sun Visors (83280-SR2-J01 ZA / 83230-SR2-J11 ZA) -JDM EG2 CR-X Del Sol SiR Gathers Rear Speaker Grills -JDM Integra Type R Recaro SRD Seats Black Suede w/ Red Stitching -NRG Steering Wheel Quick Release Exterior -MUGEN Rear Wing CR-X Del Sol EG2 -MUGEN Front Bumper CR-X Del Sol EG2 -JDM EG2 CR-X Del Sol SiR Lower Fog Lamps w/switch (08V31-SR2-600) -JDM EG2 CR-X Del Sol SiR Headlights (33100-SR2-J03) -JDM EG2 CR-X Del Sol SiR Taillights -JDM EG2 CR-X Del Sol SiR License Plate Filler Panels -JDM EG2 CR-X Del Sol SiR Side Marking Lamps (33800-SR3-J01 / 33850-SR3-J01) -JDM EG2 CR-X Del Sol SiR Rear Badge (CR-X Del Sol - 75765-SR2-J02ZE) -JDM EG2 CR-X Del Sol SiR Rear Badge (SiR - 75723-SR2-J12ZE) -JDM EG2 CR-X Del Sol SiR Side Decals (DOHC - 75772-SR2-003ZE) -JDM EG2 CR-X Del Sol SiR Side Decals (VTEC - 75774-SR2-003ZE) -JDM Rear Glass Parking Decal -JDM Front Glass Parking Decal -JDM Techlogex "Boost is Better" Decal Engine -FWHP 269 @ .6 Bar (XS Engineering) -FWTQ 183 @ .6 Bar (XS Engineering) -USDM B16A3 -TODA High Power Timing Belt Del Sol B16A (18.TD.TBB16A) -MUGEN Fan Switch Del Sol 1994-1997 (37760-XK5-00N0) -MUGEN Formula Head Cover Del Sol 1994-1997 VTEC (12310-XG7-K1S0) -MUGEN Oil Filler Cap (15610-XG7-K0S0) -MUGEN Thermostat Del Sol 1994-1997 VTEC (19301-XGER-0000) -Spoon Sports Magnetic Drain Bolt Set (90009-000) -JDM Honda Integra Type R Intake Cam -JDM Honda Integra Type R Exhaust Cam -JDM Honda Integra Type R Valvetrain -JDM GReddy High Flow Injectors 720cc (13500072) -JDM HKS SSQV Blow Off Valve w/ Steel Flange -JDM Cusco Oil Catch Can -Skunk II Adjustable Cam Gears -Koyo Aluminum Radiator -Odessey Slim Battery -MSD Ignition Wires Black/Gray -Spark Racing Stainless Turbo Manifold -Garrett T3-T4 Hybrid Turbo -Tial 38mm Wastegate -XS GTR Power Core Intercooler -Custom Intercooler Piping -Custom Downpipe -Walbro 255lph Fuel Pump (gss 342/400-846 install kit) -B&M Fuel Pressure Regulator -B&M Fuel Pressure Guage -Samco Radiator Hose Kit Exhaust -Maganaflow Muffler -JDM JGT500 Espiler B Pipe Drivetrain -Competition Clutch Stage 4 Strip Series 1620 Clutch Kit with Light Weight Steel Flywheel Suspension -MUGEN Front Tower Bar Civic 1992-2000 (74300-XGER-K1S0) -MUGEN Rear Tower Bar Civic 1992-2000 (74380-XGER-K1S0) -Spoon Sports Rear Lower Tie Bar (74351-EGA-000) -Ingalls Front Camber Kit -JDM Tein Super Street Coilovers w/Pillowball Mounts Wheels/Tires -MUGEN RNR Black w/Red Lip Wheels (42700-RNRU-1 565BL) For Sale -MUGEN Wheel Nut & Lock Set (08181-M07-K0S0-BL) -Toyo Proxes FZ4 Tires 205/50/15 Brakes -PowerStop Brake Rotors -Axxis Brake Pads ICE -Clarion DV925 Head Unit -JL Stealthbox Honda Del Sol -Kicker CVR8 Subwoofer x2 -Rockford Fosgate P3002 Amplifier -JDM EG2 CR-X Del Sol SiR Gathers Speaker System Engine Management/Electronic -JDM Defi DF Control Unit II (DF05001) -JDM Defi DF 60 Turbo BF (DF04301) -JDM A'pex Power FC (414-H003) Accomplishments: 1st Place "Baddest Del Sol" - Importfest San Diego 2003 "Best Del Sol" - Team Sol Cal Vegas Invasion IV "Best Interior" - Team Sol Cal Vegas Invasion IV 1st Place "CRX/Del Sol Class" - Extreme Autofest San Diego 2004 3rd Place "Honda Class" - Showoff Classic Chinatown 2005 Magazine Coverage: that car is one of the first ones on cardomain for del sols if you guys want to see more Link to comment Share on other sites More sharing options...
blackdelsol Posted February 1, 2006 Share Posted February 1, 2006 I swear that guy's rich Link to comment Share on other sites More sharing options...
SolLesHonda Posted February 1, 2006 Author Share Posted February 1, 2006 Hey, I'd appreciate now whoring up my thread with NOEL's del sol. That's the one you keep talking about. He is a moderator on crx forums. As far as cost, I have spent about 5K with all of this. I plan on buying a couple other little things soon, like Edelbrock intake manifold, and maybe some other little things. Link to comment Share on other sites More sharing options...
SolLesHonda Posted February 1, 2006 Author Share Posted February 1, 2006 Yes, I will, and I am going to rape BBS' crvtec. Haha just kidding. I would think it would be interesting though. Link to comment Share on other sites More sharing options...
blackdelsol Posted February 2, 2006 Share Posted February 2, 2006 n/a is more impressive though. Link to comment Share on other sites More sharing options...
SolLesHonda Posted February 2, 2006 Author Share Posted February 2, 2006 Ehh, yes and no. NA is impressive, don't get me wrong, but some turbo set ups can be equally as impressive. Most turbo set ups aren't, but that can be said about NA as well. I was just trying to get a reply out of BBS. Wanted to hear what some of the regs on here thought, instead of just the noobs. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted February 2, 2006 Share Posted February 2, 2006 sounds like a good build...glad to see you went d as i like d-series more...i think your hp figures are acurate...u gonna run ems??idk jw,,good luck,,and for daily driving i wouldnt run more then 5-8 psi as you probably want this to last..running 12 psi continuosly on thin d series cylinder walls is not the best idea although it would be fun to put 20 psi in it...on my d15 i was only able to run 14 psi then the cylinder walls gave way...thats just my input but its your engine and you can do what you want... Link to comment Share on other sites More sharing options...
SolLesHonda Posted February 2, 2006 Author Share Posted February 2, 2006 I am using Hondata s200 with boost option. Stock D16z6 sleeves can handle plenty. It's not suing stock sleeves anyway if you read the build. Even if I had stock internals I could easily run more than 5psi daily ... do you have any clue as to what your talking about ? Link to comment Share on other sites More sharing options...
BigBirdSucks Posted February 2, 2006 Share Posted February 2, 2006 Ehh, yes and no. NA is impressive, don't get me wrong, but some turbo set ups can be equally as impressive. Most turbo set ups aren't, but that can be said about NA as well. I was just trying to get a reply out of BBS. Wanted to hear what some of the regs on here thought, instead of just the noobs. man, I'm not going to down you for doing turbo. it'll be badass and I wish the best of luck to you with the setup. I'm not here to be the most respected member. I'm here to help and learn, just the same as everyone else here. turbo cars can put down some insane numbers. my tuner's civic hatch will be hitting 400whp on pump gas and he's stated atleast 600whp with race gas, higher psi, and nitrous. seriously, I'm not bothered by someone else making more power than me. I think it''ll be badass and I hope to one day get to see it in person....and that's my next goal. we need to have a Hondaforums weekend meet sometime in the summer. we need a central location for all of use though. Link to comment Share on other sites More sharing options...
sonnyjc3 Posted February 2, 2006 Share Posted February 2, 2006 and that's my next goal. we need to have a Hondaforums weekend meet sometime in the summer. we need a central location for all of use though. teehee i pick my house <3 jp and that's my next goal. we need to have a Hondaforums weekend meet sometime in the summer. we need a central location for all of use though. teehee i pick my house <3 jp Link to comment Share on other sites More sharing options...
CleanGSR Posted February 2, 2006 Share Posted February 2, 2006 Hey, I think Missouri is kind of central for the United States. I would seriously be down for a hondaforums meet. I think I'm only about 6 hours from BBS as it is. Oh, and I'm still laughing at B16A3 Del Sol saying that the motor had 500whp but wasn't in a car. I wonder what wheels they measured the whp at? I sersiously can't wait to see your setup SolLes. I'm hoping you will do some cool videos when you are done. Link to comment Share on other sites More sharing options...
B16A3 Del Sol Posted February 2, 2006 Share Posted February 2, 2006 Hey, I think Missouri is kind of central for the United States. I would seriously be down for a hondaforums meet. I think I'm only about 6 hours from BBS as it is. Oh, and I'm still laughing at B16A3 Del Sol saying that the motor had 500whp but wasn't in a car. I wonder what wheels they measured the whp at? I sersiously can't wait to see your setup SolLes. I'm hoping you will do some cool videos when you are done. Still dont know what the hell your problem is with me but ill go find the article and bring it to you... Link to comment Share on other sites More sharing options...
CleanGSR Posted February 2, 2006 Share Posted February 2, 2006 No, just explain how you could measure wheel horspower when the motor isn't in the car. There's no wheels to measure whp. Link to comment Share on other sites More sharing options...
