Jump to content
All Activity
This stream auto-updates
  1. Today
  2. Hey, I have civic with 42000km that i just bought. I did test from full tank to empty. The car did 265km for 40 liter , it make sense?? Most of my driving is urban. Thanks.
  3. Yesterday
  4. FYI: I have minimal car knowledge. Anyways, I have a 2006 Honda Civic EX with about 220,000 miles on it. My car has been starting up weak for a couple weeks prior. A few days ago I tried to start up my car to go to work. It wouldn't even crank or anything, no feedback at all. It wouldn't even make clicking sounds like when you have a dead battery. My dad charged the battery and it was able to start up later in the day, about 6 hours later when I got home from work. Went to AutoZone to get everything tested, during the test it wouldn't start up again, so they put a little charger thing on it and it started it up. They said to go to drive the car around to charge up the battery and stuff, which I did. The battery and alternator are fine apparently, they think my starter is on it's last legs, which could very well be the case. Since then, it hasn't had any trouble starting up, it hasn't even started up weak. What is going on here? I know a guy who works for Honda who has worked on my car before, should I just get my starter replaced? I don't know if I should because I don't know for a fact that it is definitely bad.
  5. Hello I'm Michael, I need some help, I've been trying to look everywhere and get some help, my civic started making some weird knocking noise from the engine, so I took it in to get it checked and comes to find out the Cylinder # 3 or valve # 3 has a piston pin that's either broken or it cracked, so after getting told the issue, he tells me it's gonna cost me 5 grand to fix it. Im like no way that's true. He tells me that it'll cost me more to rebuild it, that I'm better off getting a used engine. Can anyone help me out and tell me if I should just get the one piston fix or get another engine. Please let me know. Thks
  6. Last week
  7. I have a 2003 Accord LX w/2.4L 4cyl automatic transmission w/308k miles. It recently started to up shift roughly. It got worse to the point where it would disengage then engage again. I stopped and checked the fluid level, it was correct and did not seem burnt or discolored. After restarting the engine the transmission worked fine for about 10 minutes then the up shifts got rough and it began to disengage and engage. I then stopped and shut the engine off and then started it immediately and the trans worked fine for about 7 minutes when it began the save behavior as before. I read the ODBII codes with a basic ODBII reader and there were no codes and I had no dash warnings at all. I've read a lot of posts regarding transmission solenoid issues but none of the symptoms are the same as what I'm experiencing. The fact that the transmission works fine for a period of time after cycling the engine leads me to believe it's a control module problem or possibly a fluid clog or starvation? Thanks for any help with this.
  8. خدمات ممتازة في نقل الأثاث بأقل الأسعار لتناسب جميع عملائنا نقل اثاث خدماتنا هي في أرخص الأسعار وأعلى مستوى من الخدمات المهنية والمبتكرة، والتي تتميز بدقة عالية، والتي نجد عملائنا فقط في شركتنا، نقل اثاث دبي والتي يشرفنا أن خدمتك في أي وقت وفي أي مكان. سوف تحصل على خدمة نقل الأثاث في دبي التي توفر شركة النقل العابرة للقارات نقل اثاث العين وخروجها من دولة الإمارات العربية المتحدة. العميل هو مثال على المقيم في دبي الذي يريد نقل منزله خارج دولة الإمارات العربية المتحدة. نقل اثاث عجمان نحن نحجز حاويات التخزين لنقل الخشب والحديد والأثاث ومواد التعبئة والتغليف بشكل منفصل، قبل ترحيلهم خارج البلاد وأسعارنا تنافسية ونحن نتعمد نقل شركائنا في النقل خارج البلاد. نقل أثاث الشارقة لماذا عليك فقط أن تكون دوافع لتوظيف صاحب المنزل المهنية نقل اثاث في راس الخيمة الطريقة التي تتبع نفسك تحظى بشعبية كبيرة، لأنه في كثير من الأحيان يمكن أن يوفر لك المال. ولكن هناك بعض المهام التي من الأفضل تركها للمهنيين - نقل اثاث الفجيرة اختيار شركة مهنية لنقل منزلك يمكن أن يكون في الواقع خيارا أكثر فعالية من حيث التكلفة في كثير من الحالات. نقل اثاث ام القيوين فكر في الأمر: عندما تتعامل مع خطوتك لنقل أثاث دبي، لن تضطر فقط لدفع ثمن استئجار الشاحنة المتحركة، ولكنك تدفع أيضًا ثمن الوقود والفنادق والرسوم والمواد الغذائية وغيرها من النفقات على الطريق. قد تضطر إلى دفع الناس للمساعدة في تحميل أو تفريغ الشاحنة في أي نهاية من النقل. إذا كان هؤلاء المساعدون - المساعدين المحفزين أو الأصدقاء المتحمسين - يدمرون سلعك المنزلية، فلن تتمكن من إصلاحها أو استبدالها. مع خطوة مهنية، يتم تغطية كل هذه النفقات في تكلفة النقل، يمكنك الحصول على اثنين من محركات المهنية والسائقين المحترفين للعمل مع. إذا فقدت أي من العناصر الخاصة بك أو تضررت أثناء النقل، فمن مسؤولية الشركة المتنقلة لجعلها الحق. انظر لنفسك والحصول على اقتباس الفورية الآن. أفضل أسعار الخدمات في الإمارات العربية المتحدة خدمات توصيل الأثاث في دبي تقدم فقط الأسعار الأكثر ملاءمة وتنافسية، من خلال تزويدك بتقدير خطي للتكلفة التي ستنتقلها على أساس الخدمات التي تختارها في استبيان دبي لنقل الأثاث، حتى تتمكن من ذلك. مقارنة أسعار الشركات الأخرى. اسأل محترفي نقل الأثاث في دبي التسعير من أسفل إلى أسفل: إجمالي الرسوم هو السعر المضمون، بناء على أسعار الهاتف المحمول الخاص بك. عدم الدفع: قد تكون التكلفة في نهاية المطاف أقل من تقديرات حركة المرور، ولكنك لن تتجاوزها. التسعير حسب الطلب: يوفر هذا الخيار مجموعة من تكاليف الخدمة المضمونة المنفصلة لن تكون هناك أي رسوم إضافية ستدفع ثمن ورقة الاستطلاع فقط. إلا إذا كنت تطلب خدمات إضافية. بغض النظر عن أي من العديد من خدمات الهاتف المحمول التي تختارها، أو أي خيار التسعير، فإن خبرائنا المؤثرين حماية الممتلكات الخاصة بك والتعامل مع تحركاتك بأمان ومهنيا. اتصل بنا اليوم للحصول على عرض أسعار لخدمات النقل بأسعار معقولة التي تغطي احتياجاتك بدقة. شركة الإمارات العين لنقل الأثاث تقوم الشركة بنقل الأثاث في العين الإمارات، وشراء نقل أثاث العين حيث نقدم أقوى وأكبر فريق متكامل يضم أفضل الفنيين المتخصصين في جميع المجلات والتخصص المختلف للنجارين الذين لديهم خبرة واسعة في فك جميع أنواع الأثاث المحلي والأوروبي والصيني الأثاث ايكيا والتعامل مع نقل الأثاث دبي بدقة ومهارات عالية كما لدينا أفضل المهندسين الكهربائيين المتخصصة في تفكيك جميع الكهربائية الأجهزة بعناية وحرص ly حتى لا تسرب الغازات من الأجهزة نقل الأثاث للمنازل المحلية وأيضا لدينا عمال جيدون في التعامل مع الزجاج والألواح الزجاجية مع كل الاحتراف والمهنية عالية، مع شركتنا كنت في أمان تام ولا تحتاج أثناء نقل العجز الخاص بك إلى أي عامل إضافي، لذلك شركتنا توفي شركة نقل الأثاث دبي الإمارات متكاملة كاملة لذلك لدينا جميع العمال في جميع التخصصات لا تقلق بشأن أي شيء وكيل العزيز.
  9. Beth
    HELP, PLEASE!
    Im looking for a 1988 or 1989 red honda si prelude for sale. Im not familiar with where to find one that is in good shape. Any suggestions would be greatly appreciated! Thanks in advance! BC
  10. Beth
    HELP, PLEASE!
    Im looking for a 1988 or 1989 red honda si prelude for sale. Im not familiar with where to find one that is in good shape. Any suggestions would be greatly appreciated! If you have any info that would help me locate one, feel free to email me at bethcarter95@yahoo.com Thanks in advance! BC
  11. Make sure that the skills Listed on your profiles are not random. You have to ensure first those skills you need endorsements. Also, the skills will have to be with your vital skills. Buy LinkedIn Endorsements
  12. I just bought a 2015 and haven’t had it a month yet and it has only 31000 miles on it and the gas cap light came on today so I am hoping that the cap just needs to be replaced
  13. Hello I have a 2005 Honda Accord Euro. Over the past 2 years the car has been periodically stalling once every 6 months. When this happens, the radio loses power first, followed by all of the engine lights coming on then finally the car is unable to accelerate when placing foot on the throttle. The car then stalls. The first time this happened I thought it was the battery so that was changed. Then it happened again 6 months later, so I thought it was the alternator and changed that. It happened again, thought it may of been a dodgy battery I bought originally, so I changed it again. Now it has happened again! The battery terminals are clean. I've measured the battery charging current and voltage with the car on and all seem fine, the battery appears to be charging OK. This is happening almost 6 months to the day after repeatidly changing the battery. Has anyone else had a similar issue? Any thoughts?
  14. Does anyone know the part number for a 2011 Pilot MAF sensor connector? I cannot find a diagram or part number anywhere.
  15. الأبواب المنزلقة هي في كثير من الأحيان نقطة محورية للعديد من المنازل. سواء تم تثبيتها بالقرب من الفناء أو الشرفة، تركيب ستائر فإنها توفر الكثير من ضوء النهار للمساحات الداخلية الخاصة بك وتساعد على الحفاظ على أي منزل من يبحث الكثير من القاتمة. تركيب ستائر رول ومع ذلك، فإن البحث عن الستائر المناسبة للأبواب الزجاجية المنزلقة يمكن أن يكون من الصعب لأن هذا هو بعد كبير من المنطقة تركيب ستائر التي ينبغي استيعابها. أبواب زجاجية منزلقة لم يكن لديك أحجام موحدة لذلك لا توجد أحجام قياسية من الستائر التي يمكنك شراء. تركيب ستائر أول شيء يجب أن تنظر إذا كنت تسوق للستائر للأبواب الزجاجية المنزلقة الخاصة بك هو إذا كنت حقا بحاجة إلى الستائر على الإطلاق. هناك الناس الذين يفضلون لوحات عمودية للأبواب الزجاجية المنزلقة لأنها أرخص وأسهل للاستخدام. يمكنك التسوق بسهولة لأنواع عديدة من الستائر مع ألوان ومواد مختلفة، وأنها يمكن أن تكون مرنة جدا. إذا كان لديك الحيوانات الأليفة التي تحب أن تلعب مع الستائر، ثم لوحات عمودية عادة ما تكون مجموعة جيدة. وبصرف النظر عن الستائر، والستائر العمودية هي ديكور النافذة الكلاسيكية التقليدية. وتتكون هذه من عربات المنقولة التي يمكن رسمها أفقيا في أي من الاتجاهين لفتح النوافذ. يتم توفير عصا للسيطرة على الستائر. ومع ذلك، إذا كنت مصممة على الستائر، ثم يجب أن تقرر كيف تريد لهم مصممة خصيصا. هناك الناس الذين يحبون هم أن ينقسموا في الوسط، في حين أن هناك أصحاب المنازل الذين يفضلون واحد الأقمشة الكبيرة التي تنزلق أفقيا. هذا التفضيل مهم حقا لأنه يحدد عدد الستائر التي تحتاجها للأبواب الزجاجية المنزلقة الخاصة بك. ثم يجب عليك أيضا النظر في اللون. معظم الناس يختارون لون أخف وزنا، لأن حجم كبير من هذه الستائر يمكن أن تكون جرداء جدا في ظلال أغمق. ومع ذلك، هناك عدد قليل من السلبيات مع الصبغات أخف وزنا. إذا كنت هناك شخص في منزلك الذي يدخن، ثم هذه الستائر يمكن التقاط رائحة والبقع من التدخين. من ناحية أخرى، يمكن أن تتلاشى الستائر الداكنة إذا تعرضت بانتظام لأشعة الشمس. هل يمكن أن يكون عدة مجموعات من الستائر - طبقة الداخلية التي هي أخف وزنا في لون يسمح أشعة الشمس لتمرير من خلال وطبقة أغمق من شأنها أن تحمي الداخلية الخاصة بك من أشعة الشمس الخطرة خلال فصل الصيف، وسوف تبقى لكم دافئة خلال موسم البرد. اختيار مجموعات مزدوجة من الستائر يعني تركيب اثنين من قضبان الستار. هذا يمكن أن يكون أكثر تكلفة، ولكن يمكنك توفير المزيد من فواتير الطاقة. في نهاية المطاف، لا يمكنك النظر في شراء الستائر دون النظر في قضبان الستار التي من شأنها تأمين لهم. منذ هذه القضبان سوف تأمين الستائر التي يمكن أن تكون ثقيلة بشكل لا يصدق، ينبغي أن تكون قضبان من الصعب ارتداء. العديد من الناس مثل قضبان التي ليست مرئية، في حين أن البعض استخدام قضبان لتعزيز تصميم الستائر عن طريق إضافة تصاميم معقدة على الأقواس وينتهي. لذلك سوف يكون الأمر متروك لكم أي قضبان تختارها.
  16. Earlier
  17. Just picked up a used 2010 accord EX-L. Love the car but I found this while doing my bi-weekly under the hood inspection. It’s a very slow leak. Doesn’t leave anything on the ground when I park it overnight. I made sure the hoses connecting the power steering pump were nice and tight. Hoping it’s not the pump itself leaking.
  18. كنت قد وضعت الكثير من الوقت والجهد والنفقات في بناء موقع الويب الخاص بك والنتيجة هي أن لديك موقع رائع، المهنية جدا، تصميم مواقع والصور الجميلة، والكتابة كبيرة ومنتجاتك هي الثانية إلى لا شيء. كنت أيضا الحصول على حركة مرور جيدة نتيجة لجهود التسويق الخاصة بك. شركة تصميم مواقع ولكن هل تعلم أن الأمر يستغرق في المتوسط 7 لقاءات قبل شخص ما سوف تشتري شيئا من موقع الويب الخاص بك. تكلفة تصميم موقع الكتروني في مصر لذلك ليس فقط كنت بحاجة إلى جهود التسويق جيدة للحصول على حركة المرور، ولكن عندما يصل الزوار إلى موقعك تحتاج إلى شيء للحفاظ عليها العودة. شراء موقع والهدف ليس بالضرورة للحفاظ على تصفح الموقع لمدة نصف ساعة، ولكن للتأكد من أنها تأتي مباشرة لك في المرة القادمة، من خلال عنوان URL المباشر الخاص بك، دون النقر على يضيف مكلفة. تذكر أن هؤلاء الزوار سوف يعملون كفريق التسويق الشخصي الخاص بك إذا استمروا في العودة إلى الموقع، وسوف يوصي به للآخرين. شركة تصميم مواقع الكترونية إليك 7 طرق لمساعدتك في الحصول على 7 لقاءات. تكلفة تصميم موقع الكتروني 1- المحتوى شركات برمجة في مصر حافظ على المحتوى على قيد الحياة. وينبغي نشر محتوى جديد ومفيد بشكل متكرر. إ شركات تصميم مواقع فى مصر ذا كان موقعك هو نفسه تمامًا في كل مرة يزورونها، فلماذا يجب أن يعودوا؟ وقد أظهرت الدراسات، شركة برمجة مواقع أن الناس يعودون في كثير من الأحيان إلى المواقع التي يتم تحديثها بانتظام. فقط لأنك موقع قائم على المنتج وليس موقعًا قائمًا على المعلومات، لا يعني أنه لا يمكنك تضمين معلومات مفيدة لزوارك. مهما كانت المنتجات التي تبيعها، يجب أن يكون لديك جمهور مستهدف، والعثور على المحتوى والمعلومات التي قد تكون مفيدة لهم واستخدامها. شركة تصميم المواقع 2. القبض عليهم التقاط عناوين البريد الإلكتروني الخاصة بك الزوار هو وسيلة رائعة للبقاء على اتصال معهم. إذا كنت تستطيع تقديم تقرير مجاني أو رسالة إخبارية مثيرة للاهتمام فإنه سيتم تذكير العملاء المحتملين للعودة وزيارتك. الناس يريدون التعرف عليك بشكل أفضل حتى يتمكنوا من الوثوق بك النشرة الإخبارية الودية والإعلامية هي الطريقة المثلى لبناء العلاقة. ولكن تذكر لا تبالغ مع حجم البريد الذي ترسله لهم، التي سيكون لها تأثير عكسي. لا ترسل رسالة إخبارية من أجل ذلك، يجب عليك تضمين المعلومات ذات القيمة. 3- المسابقات من لا يحب الفوز بشيء في المنافسة؟ يمكنك الحصول على أي شيء من القسائم للإنفاق على موقعك، إلى المنتجات المجانية من مواقع أخرى. اطلب من المواقع الأخرى التبرع وتفعل الشيء نفسه بالنسبة لهم. عبر الترويج بين المواقع المجانية هو مولد حركة المرور كبيرة أيضا. 4. بلوق بلوق بلوق. المدونة هي طريقة رائعة لإضافة محتوى جديد بسهولة وتكرار إلى موقعك. يمكن للزوار الاشتراك في ذلك وإبلاغتلقائيا عندما تكون هناك تغييرات. يمكنهم إضافة تعليقات إذا سمحت بذلك، كما أنها طريقة رائعة لبناء علاقة مع العملاء المحتملين الخاص بك كما أنها تحصل على معرفة الشخص أو الأشخاص وراء المنتجات 5. المواقع الخاصة. الإعلان عن العروض الخاصة الخاصة بك في مكان معين على الموقع وتحديثه في كثير من الأحيان، ربما على جدول زمني محدد مثل؛ "خاص من الأسبوع" أو "خاص من الشهر". وهذا سوف يحصل الزوار العودة لمعرفة ما قد يكون على العرض هذه المرة. 6. التفاعل مع زوارك. يحب زوار الموقع التحدث والتفاعل مع الآخرين الذين لديهم نفس الاهتمامات. خذ بعين الاعتبار بدء منتدى رسالة أو قسم مراجعة على موقع الويب الخاص بك. يمكن للعملاء المحتملين ترك الاستعراضات أو التحدث إلى الآخرين، وسوف يعود في كثير من الأحيان للتحقق من الردود أو لإعطاء رأيهم. 7. المحتوى التسلسلي. كما أن مشاهدي التلفزيون يتناغمون في كل أسبوع لمشاهدة الحلقة المثيرة التالية من برنامجهم المفضل، يمكنك أن تفعل الشيء نفسه مع زوار موقعك على الويب. وضع جزء واحد فقط من مقال أو مراجعة أو مقتطف من مجموعة المنتجات الجديدة الخاصة بك على الموقع في وقت واحد وتشجيع الزوار على العودة الأسبوع المقبل، أو الشهر المقبل للبقية. شبكة الإنترنت في جميع أنحاء العالم تتطور بسرعة كبيرة وللحفاظ على رأس اللعبة سوف تحتاج إلى التطور معها. ليس فقط تحتاج إلى إبقاء زوارك يعودون من خلال محتوى مفيد وذي صلة، ولكن تحتاج إلى النظر في ترقية مظهرك وأسلوبك على فترات منتظمة. إنشاء موقع على شبكة الانترنت هو الجزء المثير، و "رقيق" الجزء. ولكن يجب أن تبذل الكثير من الجهد للحفاظ عليه والحفاظ عليه على قيد الحياة، لا تنسى ذلك!
  19. Hello everyone! I’m 19 and I have purchased my first manual car. I decided to go with a 2006 Honda Accord 6speed (6-6). Looking for information as to cool interior/exterior mods, and performance related mods. My car is super clean and super stock, so I definetely would like to keep it looking as OEM as possible!
  20. Had work done to correct very rough engine. Cap, rotor and plug wires replaced and car runs smooth now. Noticed next day that radio does not come on, also convenience outlet has no power. Checked pertinent fuses, both in main panel in engine bay, as well as both interior panels. All good. Even though radio display is blank, it will still load and eject a CD, so it definitely has power. Is there some "anti-theft" protection causing this?
  21. Honda mel
    2000 honda civic
    Why is my 2000 civic overheating i change raditor cap thermotat and water pump checked if my head gasket was bad and it is not
  22. Hi, I don't know if a coincidence and I have a bad battery or alternator, but I just had a new transponder key made and coded by a locksmith days ago. Now car tries to turn over but wont.
  23. So I've got a question. A few weeks ago I hit a monster pot hole in my 5th gen Prelude and did some damage. Got it all fixed for the most part, new shock, some new bushings. However one thing remains, after hitting the pothole my brakes squeal a bit. They were totally silent before it happened. Does anyone have any ideas on what could be causing it the noise? I have a feeling it's just that the pads are no longer sitting completely flat on the rotor, but if that's the case, how should I fix it? Thank you so much for any ideas!
  24. New to Honda’s and the forum thanks for reading. My sons 2004 civic manual trans was running fine back in the first week of June, but after sitting for the 30 or so days would crank but not start. Thinking the battery was drained I tried charging that first to no success. Next I figured, worn out starter(190,000 miles on car only 91k on engine) so I replaced that also no success. Watched some YouTube to see if I could figure something out, thought the worst, timing belt, so removed oil cap and tried starting it. And I did see the valves moving so I believe that is a good sign it’s not a timing belt. I have also removed the spark plugs to make sure they were getting fuel which they are getting fuel. Right now i’m thinking it’s not getting spark but not sure. Any extra knowledge would be greatly appreciated. I have attached video of what it is doing. https://youtu.be/Z3BVqAYG-Qc
  25. Hello everyone. I really need some guidance . I am dropping a rebuilt b18c1 with its transmission and ecu from my 96 integra gsr into my 95 delsol. Never done something like this but was told to upgrade the entire wheel assembly to a 5 lug system and all integra axels and such. However . I also hear that " any gsr axels and hubs will work" I'm seeing most of the gsrs out there have 4 lug hubs. Will these work? Is there a big perk to going 5 lug? Please help me out. I'm about to find a donor car to get the part from amd dont wanna waste time on the wrong bits. Thanks for the time all.
  26. Hey, if you still have the interior pieces, I need the passenger side door handle/lock assembly. And the upper seat cover for the driver side, if it’s still in good condition. It comes off with a couple of zippers in the back.. I figure It’s cheaper than shipping an entire seat. i would pay $40-50 bucks shipped depending on condition send me an email if you have those please. Flukenight@gmail.com
  27. Does anyone know what the component, circled in red in the attached photo, is called? I developed a significant oil leak that looks to be coming from that part.
  28. Frankie
    header
    Will a header from a 1.4 fit a 1.7
  1. Load more activity
Announcements
  • Create New...
Important Information
Terms of Use | Privacy Policy | Guidelines
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
