WHAT DOES OFFSET MEAN WHEN BUYING WHEELS
  • Please log in to reply
3 replies to this topic
#1 del slo team
del slo team
    Member
  • Member
  • Pip
  • 48 posts
  • Vehicles:1991 INTEGRA GS AND TOYOTA AE86
Posted 14 June 2004 - 10:19 PM
PLEASE inform me on what offset is and does to the fit. example 15x7 offset 35?
#2 CRG7
CRG7
    I rock. The end.
  • Moderator
  • 7,755 posts
  • Gender:Female
  • Real Name:Ashley
  • Vehicles:Refer to the Sig.
Posted 14 June 2004 - 10:28 PM
http://www.tirerack....tech/offset.htm
#3 TLontheDL
TLontheDL
    Elite Member
  • Moderator
  • 6,650 posts
  • Vehicles:Ridin' on SLAB
Posted 14 June 2004 - 10:29 PM
offset is the number in mm from the center of the wheel. so +35 is 35mm towards the outside of the wheel from the center of the wheel. the center of the wheel is 0. -35 is -35mm towards the inside of the wheel (towards the car). the lower the number, the fatter the lip.
#4 1010tires.com
1010tires.com
    Member
  • Member
  • Pip
  • 48 posts
Posted 15 June 2004 - 10:40 AM
The offset of a wheel is the distance from the mounting surface of the wheel to the
true centerline of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tire assembly. This in effect brings the tire in to the fender well more. Conversely, a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle.
Usually a range of offsets will work for a particular wheel size. The range is usually only 5 - 10 mm though. It really depends on the vehicle though as some have more clearance in the wheel well.
