sevenyo Posted May 26, 2016 Share Posted May 26, 2016 I just got this car and the first time i drove it was to the gas station. I got premium gas. About 30 miles later I noticed after coming to a stop and pulling off, there was a acceleration issue. More like a strain. Eventually after about 8 seconds it started to run fine again. It happened twice. I am wondering if it was the gas. I am going to use 87 from now on. Can you mess up your engine using premium gas in a 5th gen 96 accord? Link to comment Share on other sites More sharing options...
Humphries Posted May 26, 2016 Share Posted May 26, 2016 your car is not tuned to run a higher octane gasoline. run 87 and you will have the best performance if using the incorrect octane rating, you will experience pre-ignition and knocking. your knock sensor will advance or retard ignition timing to compensate but it cant be always exact. just use what is meant for the engine. Link to comment Share on other sites More sharing options...
