CRVINMICH Posted March 21, 2015 Share Posted March 21, 2015 I ran over a pretty good pothole in my 2007 CRV (Welcome to Michigan!), and damaged one of my rims. I was going to replace it with an aftermarket rim. Can I remove the old TPMS sensor from the damaged OEM rim and put it in the new aftermarket rim? Link to comment Share on other sites More sharing options...
Humphries Posted March 24, 2015 Share Posted March 24, 2015 if the rim is oem replacement, yes. you can remove it with a 12mm socket/ratchet and make sure the washers are in the right place. 66 in/lb torque. Link to comment Share on other sites More sharing options...
smoothmover Posted August 11, 2015 Share Posted August 11, 2015 Yes a TPMS can be definitely be reused. But if it is nearing the end of its average battery life, don't reuse them. Link to comment Share on other sites More sharing options...
