96 accord,,no power locks
woody31
ok on to the next issue..the power locks stopped working,,,fuse is good and there is no power to drivers side door switch,,locks do not work with pass, side switch either,,,,what is wrong,,i heard it may be the actuator.... help plz and thanks..
ok james im new to working on this honda,,plz bear with me,,no i was checking fuse with test light,,when i was checking the d,s, door lock switch,,it was with a test light,,and it showed no power as in the light was not lit,,but if it uses less then 12v at the switch then no the light wont light up,,when u say disconnect the control unit are you referring to the actuator or what/?? if not the actuator plz describe in detail,,my mom gave me this car when she passed away and it means alot to me to get these lil issues fixed,,thanks for your time and replies,,mark.
By your reply, you might have removed the door card; but if not know that you're going to need to do this to get to the control unit. All hot connections are 12v since most power distribution is in parallel; that goes for all ssystems.
While the door card is off, the control unit is that grey box you saw attached to the door behind the panel, driver's side. I can't walk you through the pin out, you need a wiring diagram. This is before multiplexers so the ground and power distribution is what I would call "dubious".
I'll look in the morning when I'm not replying to this post off the top of my head while falling asleep, but I want to say those switches are ground interruptions. So, no voltage there wouldn't be a surprise if there is an open in the circuit.
BTW when the actuators fail the stop counter level breaks or sticks causing an over run error, sometimes shorting the inductive windings which then fails to generate sufficient EMF to open the locks (tthisis the ubiquitous buzz buzz buzz people hear as their car struggles to unlock the doors) but a short in the windings doesn't mean an open to ground and usually still will look fine on a test light.
That's why I said bad actuators don't cut power to switches, necessarily. I shouldn't have said "cannot", it's just not where I would start; suspecting bad actuators when there's no power.
That reminds me, please mention anything else that's pertinent to door locks: noises, broken wires, ...car alarms.
Well, unless you have no power on the white wire going to the control unit in the door, pin 14, you probably have a bad control unit.
Unless, you neglected to mention something pertinent.
Putting a test light on two of the three wires on the driver's switch should have made something happen with the door locks.
You need to use a meter to test all your connections.
no i dont see what wire i am looking for,,hence the question,,what wires do i check,,ir how do you diagnose this thing,,in simle english plz,,im not electrical savvy and i def,,dont know what i am doing,,i no its a bad combination but,,someone plz explain what to do,,thanks
Remove the door panel on the driver's side, there will be a grey box. I'm talking about the entire door panel, not the door handle trim you removed to probe the lock switch.
On that grey box, look for a white wire
See if there's 12v on that white wire
At this point I'm just rephrasing what've already told you to do.
If you don't know what you are looking for or what you are doing, perhaps you need to start by buying the Helm Electrical Troubleshooting Manual.
thanks for the replies and your time,,i wish i had the money,,i would get it ,,but funds are extremely tight,,so ,,,,
ill check into the next area,,if there is 12 volts,,whats next??
if there is not 12 volts whats next??
again i appreciate your taking the time ,,
If there's not 12v on that wire then look for an open in the wire going from the fuse to the control unit.
If there is, it gets complicated.
So start with the control box, and we'll go from there.
First a big thanks for your time and replies,,i tried the control box first as it was by far the easiest to get to. Checked the appropriate white wire and found 13 volts,,car off,,started car and was 14.5 so i was happy,,,replaced control box and it solved my issue with the locks.
Also i replaced the hazard switch in the dash,,had a dr.pepper explode in the car several yrs ago,,it went every where and was a real pain to clean it up,,ever since the hazard switch would stick in the in posotion ,,no big deal just used a small screwdriver and pulled it out,,well it must vibrated inside,,but if you push it in just a lil the blinkers wont flash and no light flashing on the dash,,replaced switch and it works as new,,now for my next issue,,the alarm doesnt beep when you hit the button,,alarm locks the doors and works as it should ,,not sure if i want it fixed,,,lol,,,thanks again james,,i owe ya a cold one,,,cheers
i dont know,,but im pretty sue it is a add on alarm,,checked and it does have a good ground but meter didnt register voltage to power wire when alarm button is pushed,,maybe a bad speaker for the alarm?? any ideas are much appreciated,,cheers
