js156 Posted April 13, 2012 Share Posted April 13, 2012 my car can start but it drive like a champ untill it gets to tempature when i gets to tempature the red light and stop sighns appeared. it will turn off but will start up right away and run till i get to the next stop. How do you know the problem?And Is it electric problem?Is a fault code scanner can test the problem? Link to comment Share on other sites More sharing options...
civic9517 Posted June 21, 2012 Share Posted June 21, 2012 You saying it occurs @ temp is what throws me off. Many things are linked to at temp...Leaks which only occur at temp, ie, things activated, pressure problems where electronics are turned off....i have no idea... hope someone else can help Link to comment Share on other sites More sharing options...
