jdmben Posted March 11, 2011 Share Posted March 11, 2011 wheres a hole at in my firewall?? Link to comment Share on other sites More sharing options...
cmgogo Posted March 11, 2011 Share Posted March 11, 2011 where there is a hole. SERIOUSLY! JUST FAWKING LOOK here ill do it for you in baby steps 1.) Put on clothes and shoes 2.) Dont forget to breathe 3.) walk outside WITH your car keys 4.) Insert car key into door and turn to unlock car 5.) remove key 6.) Open door 7.) bend over and with your hand pull on the "hood release" lever next to where your left foot would be if you were able to get a drivers license because obviously you are too lazy to and drive 8.) stand up righty 9.) walk around to front of car 10.) open hood using the latch that is in the middle of the underside front of the hood 11.) lift hood with 1 hand while moving the prop rod into place with the other 12.) insert prop rod into hood and let the hood rest on the prop rod 13.) open eyes 14.) see hole in fire wall 15.) realize you just pissed me the fawk off with your stupid questions, and know that I will fawk with you until you pull your extra cromosone having head out of your a$$ Link to comment Share on other sites More sharing options...
b16a hatch Posted March 15, 2011 Share Posted March 15, 2011 where there is a hole. SERIOUSLY! JUST FAWKING LOOK here ill do it for you in baby steps 1.) Put on clothes and shoes 2.) Dont forget to breathe 3.) walk outside WITH your car keys 4.) Insert car key into door and turn to unlock car 5.) remove key 6.) Open door 7.) bend over and with your hand pull on the "hood release" lever next to where your left foot would be if you were able to get a drivers license because obviously you are too lazy to and drive 8.) stand up righty 9.) walk around to front of car 10.) open hood using the latch that is in the middle of the underside front of the hood 11.) lift hood with 1 hand while moving the prop rod into place with the other 12.) insert prop rod into hood and let the hood rest on the prop rod 13.) open eyes 14.) see hole in fire wall 15.) realize you just pissed me the fawk off with your stupid questions, and know that I will fawk with you until you pull your extra cromosone having head out of your a$$ GOOD ONE cmgogo LMFAO!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
OTiS Posted March 16, 2011 Share Posted March 16, 2011 ouch. just...ouch Link to comment Share on other sites More sharing options...
