jeffs91crxsi Posted February 3, 2011 Share Posted February 3, 2011 Ok so I just bought a 91 crs si and its kinda old she has 200000 miles on it no biggie ima swap it asap but I'm curious on what's wrong ok I did a tune up wires plugs car rotor fuel pump all that ok and still when I take off from a incline like stoped on a hill and take off it boggs down like no power at all my foot is to the floor and it slowly takes off till like 2000 rpms then it like all of a sudden comes alive u guys got any idea what it could be ??? Link to comment Share on other sites More sharing options...
Jaysta-rex Posted February 3, 2011 Share Posted February 3, 2011 Id reccomend checking you o'2 hoses and make sure their not ripped brock or punctured!! I had the same thing happen to me when I put on my cold air intake! Idk how I hit or even touch my o2 hose but when I started my car I didn't want to stay on if I didn't take the rmps up to 2500!!! Luckly it was a cheap fix! Link to comment Share on other sites More sharing options...
jeffs91crxsi Posted February 3, 2011 Author Share Posted February 3, 2011 Id reccomend checking you o'2 hoses and make sure their not ripped brock or punctured!! I had the same thing happen to me when I put on my cold air intake! Idk how I hit or even touch my o2 hose but when I started my car I didn't want to stay on if I didn't take the rmps up to 2500!!! Luckly it was a cheap fix! Ok ill double check em but I'm thinkin its like the air fuel mixture like maybe my injectors ima check after skool today Link to comment Share on other sites More sharing options...
Raley Posted February 4, 2011 Share Posted February 4, 2011 has it done it since you got the car? kinda sounds like timing is off or the fuel filter/pump is clogged... and what o2 hoses? the only O2 thing i can think of is the sensor on the exhaust... im lost with your terms. Link to comment Share on other sites More sharing options...
jeffs91crxsi Posted February 4, 2011 Author Share Posted February 4, 2011 has it done it since you got the car? kinda sounds like timing is off or the fuel filter/pump is clogged... and what o2 hoses? the only O2 thing i can think of is the sensor on the exhaust... im lost with your terms. ya its done it since I've had it and a clogged fuel pump will cause a bog .?? I might change that then Link to comment Share on other sites More sharing options...
Raley Posted February 4, 2011 Share Posted February 4, 2011 Rarely, but possible. My main suggestion is timing. Link to comment Share on other sites More sharing options...
jeffs91crxsi Posted February 4, 2011 Author Share Posted February 4, 2011 Rarely, but possible. My main suggestion is timing. Ok ill check the timing this weekend thankks a lot it was just pissin me off cause I can't figure it out Link to comment Share on other sites More sharing options...
Jaysta-rex Posted April 1, 2011 Share Posted April 1, 2011 hey man any luck??? Link to comment Share on other sites More sharing options...
