I got the JL Stealthbox in my sol, and it seems its got a bit of a flatulence problem! When the bass goes pretty low down, the sub farts like hell. I think it's only the sub on the left hand side, you guys think this sub has reached the end of its life? It seems to be ok n pretty powerful apart from when the audio frequency goes down below a certain level, I don't think I've got it turned up too high, well it shouldn't be anyway cos the amp can go a load higher, and the stealthbox should be able to handle some decent bass.
Its just pissing me off at the mo, cos I listen to drum n bass, it does it like all the time!
Time for a new one? If so, i dunno if I ought to replace it with the same sub, or see if I can get a more powerful sub to put in the box. shame is it's only an 8 inch sub.
