90 Integra
  • Please log in to reply
5 replies to this topic
#1 ShawnTheMenace
ShawnTheMenace
    New Member
  • Member
  • 21 posts
  • Gender:Male
  • Real Name:Shawn
  • Vehicles:1990 Acura Integra LS
Posted 18 October 2010 - 04:57 AM
I own 2 90 Integra LS's both TAN.. 1's for track & the other is to get the family around.
Well the Family car is acting funny.. It runs great once its been warmed up from the day! Say its been sitting for awhile & we go to leave somewhere I always warm it up til idle is at 1k or under. Now this is the first start of the day. Once the Temp gauge hits a norm operating temp the cars idle jumps from 1k rpm -1.5k rpm acting like its got a vacuum leak.. Shut the car off for a few minutes & fire it back up the problem ceases to exist for the rest of the day.. so as long as you keep driving it! The GF states that itll die sometimes when putting it into Neutral! Whats funny is it does it for her & not me!
My thoughts
-Idle Air Contol Valve (May Need Cleaning)
-Thermostat (Replace)
-Thermostat Switch (Replace)
-Pressure Regulator Cut-off valve (Clogged)
-Purge Cut-off valve (Clogged)
ANY IDEAS?
Edited by ShawnTheMenace, 18 October 2010 - 04:58 AM.
#2 Turtlehead
Turtlehead
    Senior Member
  • Member
  • PipPipPip
  • 398 posts
  • Vehicles:Accord and Tacoma
Posted 22 October 2010 - 12:45 PM
I'd start by cleaning the throtle body and plate by manually opening the throtle so you can reach in there with a rag and throtle cleaner and get it cleaned well. Spray some throtle body cleaner in the IACV port while you are in there. If not then it could also be the engine coolant temperature sensor has failed (should be on the cylinder head below the distributor cap. A likely cause of your problem. Other then that you pretty much nailed the other common causes for your issue in your post. Good luck.
#3 cranny
cranny
    i keep them running
  • Member
  • PipPipPipPipPipPipPip
  • 6,449 posts
  • Gender:Male
  • Real Name:jeff
  • Vehicles:2001 Honda Civic Type S
Posted 08 December 2010 - 09:33 PM
FITV fast idle thermal valve. located under the throttle body with a coolant line going in and comming out of it. remove those 2 lines , the throttle cable and plugs from the throttle body. remove the thottle body. on one end of the FITV there is a plate with 2 screws holding it on. remove that. you will see a round tipped plunger inside surrounded by a white plastic ring with a groove on each side of it , like a flathead screw. using a flathead , wind that white plastic ring in all the way tight again. righty tighty. than put it all back together.
#4 ShawnTheMenace
ShawnTheMenace
    New Member
  • Member
  • 21 posts
  • Gender:Male
  • Real Name:Shawn
Posted 05 November 2011 - 11:21 PM
It was totally the FICV, thanx man... I cleaned it all up & tightened it back down! its been running awesome since your post.
#5 Raley
Raley
    Platinum Member
  • Member
  • PipPipPipPipPip
  • 2,118 posts
  • Vehicles:92 Sol Wagon
Posted 06 November 2011 - 06:51 AM
wow that was delayed... fitv always gives me problems... since you cleaned and tightened it, it will probbaly loosen up on a year or 2... mine aways does.
#6 del_slo_si
del_slo_si
    New Member
  • Member
  • 8 posts
  • Gender:Male
  • Real Name:Nick
  • Vehicles:1993 civic del sol si
Posted 15 December 2011 - 04:15 PM
this happened to a buddy of mines girlfriends gsr. he said it was her thermo idle valve. apparently its under the throttle body and gives similar results to the iac valve. hope i could help
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
