M a t s u s h i t a CQ-JH1610Z & CQ-JH0712Z
  • Please log in to reply
3 replies to this topic
#1 James Matteu
James Matteu
    Platinum Member
  • Member
  • PipPipPipPipPip
  • 1,734 posts
  • Gender:Male
  • Vehicles:1997 Honda Accord EX-V6
Posted 16 September 2010 - 02:01 PM
The M a t s u s h i t a CQ-JH1610Z (Honda P/N 39100-SV4-A500) was optional equipment for the USDM 1994-97 Honda Accord DX, LX, and EX; but standard on the 1997 Honda Accord Special Edition. The M a t s u s h i t a CQ-JH0712Z (Acura P/N 39100-SY8-A010) came standard on the 1997-99 Acura CL with a BOSE version being the option. The removal procedure may apply to other Honda Single Disc CD Players with a Single-shaft Rotary Switch type Knob.
I bought the Acura CQ-JH0712Z off a 1998 Acura CL 2.3 Base in the salvage yard. The unit had problems from day one: the outputs all had severe static and the internal amplifier was slow to warm up, it would start at a whisper and then slowly the volume would rise on its own no matter what I did with the volume knob. I bought a Honda replacement from Craigslist and it had no power problems, but the knob had a bad wiper: I would turn the knob to raise the volume and it go down; I had to turn the knob slowly in order to get it to function. So I had a bad Acura radio with a good Acura knob and a bad Honda knob on a good Honda radio.
Tools
Posted Image
Instructions
Step 1. Remove the radio.
Step 2. Using the Phillips head screw driver, unscrew the face by removing the two Face Screws on the sides of the CD Player.
Posted Image
Posted Image
Step 3. Using the straight-slot screw driver, Pry the face off by starting on one side and working your way around the CD Player. Use gentle pressure and complete the prying in several steps; i.e. do not pry the left side off all at once, give it a little nudge and then keep moving around.
Posted Image
Posted Image
Posted Image
Posted Image
Step 4.1. Remove the knob.
Posted Image
Step 4.2. Unscrew the Printed Circuit Board (PCB) from the face.
Posted Image
Step 4.3. Remove the PCB from the face by both pushing on the A.SEL/RPT button and the black face tab behind the A.SEL/RPT button so that the PCB will clear the tap shown below.
Posted Image
Posted Image
The knob looks like many of the 12mm Rotary Encoder Switches I have been finding on the internet for ~$2 each but I don't know enough about the one in the CD Player to find an appropriate replacement. The switch knob is soldered into the PCB, and cannot be simply unplugged, the solder must be sucked off before a new switch knob can be soldered in place. I swapped the entire face PCB from the Acura CD Player, knob and all. Works perfectly.
Reassembly
Step 5. Perform Step 4 in reverse.
Step 6. Push the face back onto the CD Player, it will snap in place.
Step 7. Perform step 2 in reverse.
Step 8. Perform step 1 in reverse.
#2 mm1827
mm1827
    New Member
  • Member
  • 5 posts
Posted 14 April 2011 - 03:19 AM
The switch knob is soldered into the PCB, and cannot be simply replica gucci online unplugged, the solder must be sucked off before a new switch knob can be soldered in place. I swapped the entire face PCB from the Acura CD Player, knob and all. Works perfectly.
#3 bobo
bobo
    New Member
  • Member
  • 5 posts
  • Vehicles:etge
Posted 02 November 2011 - 07:34 PM
This is my first time i visit here. I found so many entertaining stuff in your blog, especially its discussion. From the tons of comments on your articles, I guess I am not the only one having all the leisure here! Keep up the good work.
Cheap Canada Goose
Cheap Herve Leger
Moncler Jackets Cheap
#4 handsomehero
handsomehero
    New Member
  • Member
  • 3 posts
  • Vehicles:benz
Posted 22 December 2011 - 06:56 PM
I really wish I hadn’t seen this as I really want one now!
Monster Beats Pro
Cheap Mac Cosmetics
Mac Makeup Wholesale
Beats By Dr Dre Solo HD Red
Dr Dre Beats Pro
Monster Beats By Dr Dre Studio
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
