HONDA CRX 88 SI Posted June 1, 2010 Share Posted June 1, 2010 It has had me asking the question for many years what exactly is final drive is it the teeth count of differential and the gear that drives it or what it is. Link to comment Share on other sites More sharing options...
mpearce1974 Posted June 1, 2010 Share Posted June 1, 2010 This is the ratio that describes the difference between the number of times the driveshaft must turn before the axle shaft turns once. In a final drive ratio of 3.55:1, for example, the driveshaft must turn 3.55 times before the axle will turn once. The number of teeth on the ring and pinion gears determine the ratio. Link to comment Share on other sites More sharing options...
HONDA CRX 88 SI Posted June 2, 2010 Author Share Posted June 2, 2010 Nice then i had it right then, but i was just a lil confused on the part that if any of the 5 gears would affect the final drive ratio if they where to be changed. Link to comment Share on other sites More sharing options...
..SSR.. Posted June 2, 2010 Share Posted June 2, 2010 Final drive is the countershaft and ring gear. Lower FD (higher numerically) = lower top speed in each gear but faster acceleration. So if you want to hit lightspeed, you don't want a 4.7 or 4.9 FD. Link to comment Share on other sites More sharing options...
