redneck Posted May 26, 2010 Share Posted May 26, 2010 first off whats open header exhaust?? second what the pros and cons to open header exhaust and a exhaust system with headers muffler bigger piping...ect. just read a thread under "noob question" and i was wondering if anyone would help me out.... Link to comment Share on other sites More sharing options...
SpeedDemon Posted May 26, 2010 Share Posted May 26, 2010 it means that after your header you have no more exhaust. it is extremely loud, will make you dizzy, get you a ticket because it is not legal(no cat) get an aftermarket exhaust. 2.25" is fine for n/a motors. if turbo or a built n/a motor go 2.5" Link to comment Share on other sites More sharing options...
redneck Posted May 26, 2010 Author Share Posted May 26, 2010 it means that after your header you have no more exhaust. it is extremely loud, will make you dizzy, get you a ticket because it is not legal(no cat) get an aftermarket exhaust. 2.25" is fine for n/a motors. if turbo or a built n/a motor go 2.5" i thought open wxhaust could blow up ur motor.... i think thats what happened to my truck cuz no back pressure..... Link to comment Share on other sites More sharing options...
SpeedDemon Posted May 26, 2010 Share Posted May 26, 2010 nope. but over revving will lol Link to comment Share on other sites More sharing options...
lastresort576 Posted May 27, 2010 Share Posted May 27, 2010 the no back pressure theory is there to an extent on a 4-stroke engine, however it is A LOT more prevalent on a 2-stroke and you'd lose a ton of power. but the only time you could safely run an open DP(down pipe) is after a turbo since there is no back pressure and it just flows out. Link to comment Share on other sites More sharing options...
SpeedDemon Posted May 27, 2010 Share Posted May 27, 2010 the no back pressure theory is there to an extent on a 4-stroke engine, however it is A LOT more prevalent on a 2-stroke and you'd lose a ton of power. but the only time you could safely run an open DP(down pipe) is after a turbo since there is no back pressure and it just flows out. very very true. you get rep Link to comment Share on other sites More sharing options...
redneck Posted May 27, 2010 Author Share Posted May 27, 2010 very very true. you get rep ohh ok. thats good to know. thanks.btw whats my redline? iv got a 1992 dx civic 4dr stalk motor from factory. sry forgot the ingine code by the time i get a chance to look at it it would be after work tomorrow. Link to comment Share on other sites More sharing options...
lastresort576 Posted May 27, 2010 Share Posted May 27, 2010 ohh ok. thats good to know. thanks.btw whats my redline? iv got a 1992 dx civic 4dr stalk motor from factory. sry forgot the ingine code by the time i get a chance to look at it it would be after work tomorrow. It's a d15b7, and the stock redline is 7200rpm. Same as an LS. Link to comment Share on other sites More sharing options...
SpeedDemon Posted May 27, 2010 Share Posted May 27, 2010 well its probably the d15b7 sooo 6800rpm Link to comment Share on other sites More sharing options...
lastresort576 Posted May 27, 2010 Share Posted May 27, 2010 well its probably the d15b7 sooo 6800rpm guess you're right, I lied. Been a few years since I had one. Link to comment Share on other sites More sharing options...
SpeedDemon Posted May 27, 2010 Share Posted May 27, 2010 i didnt even see your post lol. o well it happens. i know a dx wont be that high. the d16z6 is only ~7200 Link to comment Share on other sites More sharing options...
Humphries Posted May 27, 2010 Share Posted May 27, 2010 all hondas rev to 11k Link to comment Share on other sites More sharing options...
redneck Posted May 28, 2010 Author Share Posted May 28, 2010 all hondas rev to 11k it is a d15b7. napa told me it was between 4000 and 5000 so i set my tach at 4.5 and have not reved it up any higher than that. so to be on the safe side should i set it to 6000???? Link to comment Share on other sites More sharing options...
lastresort576 Posted May 28, 2010 Share Posted May 28, 2010 it is a d15b7. napa told me it was between 4000 and 5000 so i set my tach at 4.5 and have not reved it up any higher than that. so to be on the safe side should i set it to 6000???? It's already got a rev limiter..I found that It ran and shifted smoother when I only tacked it up to like 6200rpm instead of maxing it out..But your call, drive it ho you want to. Just remember the higher you tach it up the more fuel you use. Link to comment Share on other sites More sharing options...
redneck Posted May 28, 2010 Author Share Posted May 28, 2010 It's already got a rev limiter..I found that It ran and shifted smoother when I only tacked it up to like 6200rpm instead of maxing it out..But your call, drive it ho you want to. Just remember the higher you tach it up the more fuel you use. well i want tyo play with it but not blow it up its my daily driver..my other motor (same one) is the one i asked if its worth supin up ( i made a new subject bout it) i dont really want to blow up the one in the car lol. so 6k is in a safe zone? i was afraid i went to 5k it would blow. Link to comment Share on other sites More sharing options...
