DIY M a t s u s h i t a CQ-LH1410S
  • Please log in to reply
7 replies to this topic
#1 James Matteu
James Matteu
    Platinum Member
  • Member
  • PipPipPipPipPip
  • 1,734 posts
  • Gender:Male
  • Vehicles:1997 Honda Accord EX-V6
Posted 27 December 2009 - 08:40 PM
M a t s u s h i t a CQ-LH1410S Rotary Switch Knob Removal
The M a t s u s h i t a CQ-LH1410S (Honda P/N 39100-SV4-A000) was the stock head unit that came on my 1997 Honda Accord EX-V6. The removal procedure may apply to other Honda units with a Single-shaft Rotary Switch type Knob. My Switch Knob started to loose its ability to switch the head unit off. The ALPS website lists the longevity of some of their switches as being 15,000 cycles. I guess switching the head unit off everytime I went to turn the car off was a habit that put some additional wear on the Switch Knob Posted Image.
Tools
Posted Image
Instructions
Note: Keep track of which screws go where, they vary in length and are organized by the fastener's ability to impact other components within the head unit.
Step 1. Remove the radio.
Step 2. Remove the top cover by prying up on it at the points shown below.
Posted Image
Step 3.1. Remove the bottom cover by first removing screw numbers one and two shown below.
Posted Image
Step 3.2. Now pry the bottom cover off at the points shown below.
Posted Image
Step 4. Remove the back cover by removing the: Left Connector screw (LC), Right Connector screw (RC), Left CD Changer Connector screw (LCHG), Right CD Changer Connector screw (RCHG), and screw number three; all shown below.
Posted Image
Step 5. Remove the left cover by removing the: Heat Sink screw (HS), Left Face screw (LF), and screw numbers four and five. Pry the bottom of the face first, the left cover is hooked at the top and will need to swing up to come out; pry the top of the face second to get the cover free from the unit.
Posted Image
Posted Image
Step 6.1. Remove the right cover by first removing the Antenna screw (Ant).
Posted Image
Step 6.2. Now remove the: Right Face screw (RF), and screw numbers six and seven. Pry the Face at the bottom then top to release the right cover in a similar method as used on the left cover.
Posted Image
Step 7.1. GENTLY remove the knobs from the unit.
Posted Image
Step 7.2. The Face is only held at the top. To remove the Face, pry at the three points shown below. Careful, the Face has three connectors at the bottom and the circuit board where all the buttons are attached is only loosely held to the black plastic.
Posted Image
Step 8. Remove the Cassette Player by removing the Cassette Player's: Left-Front (CPLF), Right-Front (CPRF), Left-Rear (CPLR), and Right-Rear (CPRR) screws; and unplugging the Cassette Player's side-connector. The screws holding the Cassette Player in were torqued down really tight, I pressed the precision phillips screw driver down while holding the shaft with the pliers to exert sufficient torque to break them free. I also used the pliers to pull the connector from its plug. Be careful with the Cassette Player's back-connector, it would not come free for me and pulling on it seemed to stress the circuit board below.
Posted Image
Step 9.1. Remove the Knob-Switch by first removing the Knob Switch screw (KS) located on the front of the unit.
Posted Image
Step 9.2. Now pry the Knob-Switch away from its connector.
Posted Image
Now you have removed the Knob Switch.
Posted Image
The marking on the back of mine says "ALPS" "JAPAN", the top has "503", "6", and "XV". The board it is mounted on may actually have been purchased by M a t s u s h i t a from another manufacturer. A few websites say that M a t s u s h i t a is actually a subsidiary of Panasonic, and they do share a similar format for product numbers. The Knob Switch is a rotary potentiometer with dual resistor units and a single side tap. By inspecting the Switch Knob and reviewing the ALPS website, I have noted the following:
Manufacturer: ALPS Electric Co., Ltd.
Part No.: ?
Switch Type: Single-shaft with rotary switch type
Shaft Length: 25mm
Mounting Direction: Horizontal Type
I have tried to search their database for a simillar switch, but have had no luck. Even if I found it, they list an order unit as being 500-800 switches. I think the next time I am in the salvage yard I will tear into a few head units and pull the switches out.
Re-assembly
Step 10. Perform step 9 in reverse.
Step 11. Perform step 8 in reverse. Use the pliers to re-connect the Cassette Player.
Step 12. Perform steps 6 and 5 in reverse.
Step 13. Perform step 4. Remember, there is a single threaded hole to the top-right of the back cover that is used for a CD Changer Cable Hold that was not shown above; leave this hole empty.
Step 14. Perform steps 3 and 2 in reverse.
Step 15. Perform step 7 in reverse.
Step 16. Perform step 1 in reverse.
Thanks for reading, this thread goes to show that we can all benefit when I am bored.
Edited by James Matteu, 28 December 2009 - 06:48 PM.
#2 Xeryon
Xeryon
    As usual, slacking off instead of working...
  • Member
  • PipPipPipPipPipPipPip
  • 6,602 posts
  • Gender:Male
  • Vehicles:Any car with wheels and, occasionaly, some without.
Posted 27 December 2009 - 11:10 PM
You posted this and not one pic works :(
#3 wannaBstuntin
wannaBstuntin
    #14 All-Time Post Whore
  • Member
  • 6,662 posts
  • Gender:Male
  • Real Name:Ryan
  • Vehicles:2005 Civic EX S.E. Coupe
Posted 28 December 2009 - 06:07 PM
+1...and where the hell have you been?
#4 James Matteu
James Matteu
    Platinum Member
  • Member
  • PipPipPipPipPip
  • 1,734 posts
  • Gender:Male
Posted 28 December 2009 - 06:51 PM
The forum doesn't like my use of folders in Photobucket, and it changed M a t s u s h i t a into Matsucrapa, hence the spaces. Anyways, I moved the photos and fixed the first post.
I have been here, I do more viewing these days than anything else.
Edited by James Matteu, 28 December 2009 - 06:52 PM.
#5 airjordan223
airjordan223
    Lloyd Banks aka The PLK
  • Moderator
  • 12,421 posts
  • Gender:Male
  • Real Name:His Airness
  • Vehicles:1993 Honda Del Sol S, 2002 Audi A4 Quattro 3.0
Posted 28 December 2009 - 07:49 PM
good work my friend.
you get award for most stickied threads!
#6 Xeryon
Xeryon
  • Member
  • 6,602 posts
  • Gender:Male
Posted 28 December 2009 - 09:12 PM
For the record: Matsush ita and Panasonic were indeed the same company producing sibling electronics for many years at the time your stereo was built. In the computer world their products are interchangeable and often are identical save for the name on the casing.
#7 bobo
bobo
    New Member
  • Member
  • 5 posts
  • Vehicles:etge
Posted 02 November 2011 - 07:37 PM
This is my first time i visit here. I found so many entertaining stuff in your blog, especially its discussion. From the tons of comments on your articles, I guess I am not the only one having all the leisure here! Keep up the good work.
Cheap Canada Goose
Cheap Herve Leger
Moncler Jackets Cheap
#8 handsomehero
handsomehero
    New Member
  • Member
  • 3 posts
  • Vehicles:benz
Posted 22 December 2011 - 06:53 PM
Thank you for this article. That’s all I can say. You most definitely have made this post into something special. You clearly know what you are doing, you’ve covered so many bases.Thanks!
Monster Beats By Dr Dre Studio
Beats By Dr Dre Pro Headphones
Monster Beats Pro
Cheap Mac Cosmetics
Mac Makeup Wholesale
Dr Dre Beats Pro
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
