littlemanx23 Posted December 8, 2008 Share Posted December 8, 2008 It's a little odd what it does, but anyways. It's like it just refuses to shift after the transmission gets around operating temperature (after about 20-25 minutes of driving), it gears down and sticks in 3rd, and then sometimes when it gets worse, it'll downshift to 2nd and won't go any higher. The engine revs continuously and does not shift. I've replaced the speed sensor (speedometer wasn't working, still isn't.) seeing if that'd help anything, but it didn't. Are Honda's just that picky as to what fluid you use in them (I've been using Castrol Import-Vehicle ATF, the fluid in it leaks a bit and I have to keep an eye on it). Is this something sort of like overheating? What could the problem here? Any help is appreciated. Link to comment Share on other sites More sharing options...
Kastigir Posted December 8, 2008 Share Posted December 8, 2008 It's a little odd what it does, but anyways. It's like it just refuses to shift after the transmission gets around operating temperature (after about 20-25 minutes of driving), it gears down and sticks in 3rd, and then sometimes when it gets worse, it'll downshift to 2nd and won't go any higher. The engine revs continuously and does not shift. I've replaced the speed sensor (speedometer wasn't working, still isn't.) seeing if that'd help anything, but it didn't. Are Honda's just that picky as to what fluid you use in them (I've been using Castrol Import-Vehicle ATF, the fluid in it leaks a bit and I have to keep an eye on it). Is this something sort of like overheating? What could the problem here? Any help is appreciated. Fluid leaks, and you're asking what the problem is? Link to comment Share on other sites More sharing options...
littlemanx23 Posted December 9, 2008 Author Share Posted December 9, 2008 Fluid leaks can cause all of that? =\. Damn..sounds like I really need to get it fixed now. */Sigh. Link to comment Share on other sites More sharing options...
littlemanx23 Posted December 12, 2008 Author Share Posted December 12, 2008 Okay...I fixed the leak in it, topped it off with Honda ATF. It still downshifts violently after 15-20 minutes or so of driving. I can hear vtec kicking in at that point. This is really starting to discourage me...what could this be? Link to comment Share on other sites More sharing options...
frostedflake Posted December 12, 2008 Share Posted December 12, 2008 it almost sounds like the shift solenoids on the outside of the tranny arent working properly. I would have somebody take a look at them, and also check the computer for codes. Link to comment Share on other sites More sharing options...
littlemanx23 Posted December 12, 2008 Author Share Posted December 12, 2008 That's what I'm having checked by a mechanic on Monday. He told me the solenoids on that transmission are external, and if they need replacing, they aren't that difficult to fix and I'd be on my merry way on down the road. Link to comment Share on other sites More sharing options...
frostedflake Posted December 13, 2008 Share Posted December 13, 2008 I hope that fixes it, it would suck if your tranny totally went out to lunch. Link to comment Share on other sites More sharing options...
littlemanx23 Posted December 13, 2008 Author Share Posted December 13, 2008 I know....I've been looking around at prices of a used one just in case if it does. Cheapest I'm seeing is 300 for a used with ~100k Link to comment Share on other sites More sharing options...
frostedflake Posted December 13, 2008 Share Posted December 13, 2008 If worst comes to worst just make sure whatever one you get actually works. Link to comment Share on other sites More sharing options...
littlemanx23 Posted December 15, 2008 Author Share Posted December 15, 2008 Well. As an update. The transmission is going to get rebuilt. I decided not to buy a used...I'd rather just start new, knowing that It'll last a long time. Long enough for the engine to hold out, at least. Lol...I know Honda engines have a good lifetime on their engines. Far as I know, the engine has around 96-97k on it. Don't plan to race, so hopefully the transmission and engine will last as long as I get on through college (currently 17 right now, one more year of high school then 2 of college...) Link to comment Share on other sites More sharing options...
kravinof Posted March 12, 2009 Share Posted March 12, 2009 My car is having similar issues. It ususally wont shift on its own so i have to let my foot off the gas to get it to shift it anywhere after 3500-4000 rpm. it sometimes shifts 1st and 2nd gear but rarely higher than that. im probably gonna get a tranny flush and put new fluid in and hope for the best. any suggestions? Link to comment Share on other sites More sharing options...
