Headlights???
hondadrifter
okay my friend just got the 3 beam style headlight projectors at scummit today and we took the car back to his house and i put them in for him......by the way his car is a 98 4dr lx.....okay anyways the lows do not work b/c a honda headlight is meant to run lows and highs off one bulb well these run two and has a jumper with a fuse blah blah blah anyways i grounded them off and only one works.....how come the lows don't get any juice.....the bulbs are fine and so are the fuses......stuck help?
did you check all your connections? i'm, pretty sure you did but it never hurts to double check i believe their should be two pos. wires from your batt. right? check the conn.'s on those (honk the horn, check your blinker fluid and change the radio station and kick the passengers rear tire.) if not call the company back and tell them their stuff sucks. :laugh:
