Just installed turbo on ls...Questions
#1
Posted 04 June 2008 - 09:41 PM
-the usual t3/t4 hybrid
-38mm wastegate
-full piping
-greddy type rs bov
-edlebrock 255hp fuel pump
-AEM high volume fuel filter
-blox fuel pressure regulater
-blox vaccum box
-manual boost controller
-2.5 inch indivia test pipe with O2 sensor installed
-2.5 inch down pipe wtih O2 installed
-Moroso oil pan
-Chipped p28 Converted to obd1
-after market radiator and fan
I now i may need a few other things so let me know.
I just installed the new ecu tonight.and the car ran alot alot better than it did befor with the stock ecu.
But the car still bogs when i hit like 5 grand and getting up there is not as quick as it should be. is the car bogging like that because of the fuel pump or because its not tuned.The store i bought my ecu said it was for a boosted non vtec application so there shouldnt be anyproblems with that.
And once i get the car tuned should i feel a dramatic increase in power cause right now it feels like its almost fast as like an rsx type-s.
And just to make sure that my boost/vaccum lines a running right. i ran a line from the turbo itself to the boost controller then from the boost controller to a 3 way fiiting one going to the wastegate actuator and one going to the vaccum box, and i left the hole on top of the wastegat open.i was told that was used for a electronic boost controller.Is this setup right.
Thanks A lot....
#2
Posted 04 June 2008 - 09:55 PM
Edited by SNooPYjdm, 04 June 2008 - 10:03 PM.
#3
Posted 04 June 2008 - 09:58 PM
any pics?
and I think it would run better when it's tuned
#4
Posted 04 June 2008 - 10:03 PM
-38mm wastegate
-full piping
-greddy type rs bov
-blox vaccum box
-Moroso oil pan
Thanks A lot....
Just run a vac line from the compressor outlet to the boost controller, the to the side of the gate. I wouldn't boost it to much unless you have a wideband. Not just an O2 sensor hooked up to a gauge. Make sure its a wideband. I still wouldn't boost it until it was tuned. You shouldn't need a boost controller on a basic map anyways just run off the gate. Also who "chipped" your ECU? Make sure its lagit cause your motor is on the line. Also do you have Injectors?
#5
Posted 04 June 2008 - 10:15 PM
#6
Posted 05 June 2008 - 06:59 AM
#7
Posted 05 June 2008 - 04:04 PM
::EDIT:: im not too sure but he should get 550cc injectors right?
Edited by CT9A, 05 June 2008 - 04:05 PM.
#8
Posted 05 June 2008 - 07:13 PM
#9
Posted 05 June 2008 - 08:18 PM
#10
Posted 05 June 2008 - 10:43 PM
#11
Posted 06 June 2008 - 01:46 AM
#12
Posted 06 June 2008 - 02:40 AM
#13
Posted 06 June 2008 - 11:14 AM
#14
Posted 06 June 2008 - 07:27 PM
Edited by CT9A, 06 June 2008 - 07:28 PM.
#15
Posted 07 June 2008 - 12:18 AM
did you retard the timing at all?
#16
Posted 07 June 2008 - 10:05 PM
and im prob gonnna et 440 cc injectors.
#17
Posted 09 June 2008 - 06:48 PM
#18
Posted 28 December 2011 - 11:36 PM
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
