fdghrfhdrstrferfdvb Posted April 23, 2003 Share Posted April 23, 2003 I just purchased my 96 accord with a 2.2 non vtec and looking into swapping in a vtec head. But need more info on this. I was told it's been done and pretty easy but need a list of things I need to make this swap smooth. Any help would be great! Should I use a single cam or dual cam head? Thanks again Link to comment Share on other sites More sharing options...
midwest_tunerz Posted April 23, 2003 Share Posted April 23, 2003 I just purchased my 96 accord with a 2.2 non vtec and looking into swapping in a vtec head. But need more info on this. I was told it's been done and pretty easy but need a list of things I need to make this swap smooth. Any help would be great! Should I use a single cam or dual cam head? Thanks again I would also like to know about swapping a DOHC VTEC head onto my F22a1 2.2L non vtec motor if anyone has any I want to know also. thanks. Link to comment Share on other sites More sharing options...
joecollins2 Posted July 1, 2003 Share Posted July 1, 2003 I was going to answer that question but then you asked about a DOHC VTEC head. Have you ever popped your hood? Look at the damn vavle cover. Does it look wide enough for a DOHC VTEC cover? No. It doesn't. So imagine everything else underneath that little black cap that it doesn't have that a DOHC has. Like maybe another CAM?? Link to comment Share on other sites More sharing options...
midwest_tunerz Posted July 1, 2003 Share Posted July 1, 2003 hey butthead I meant to put sohc head but a dohc can fit with mods. anyways I need info on swapping a vtec SOHC head. Link to comment Share on other sites More sharing options...
VR17 Posted July 1, 2003 Share Posted July 1, 2003 I would also like to know about swapping a DOHC VTEC head onto my F22a1 2.2L non vtec motor if anyone has any I want to know also. thanks. it wont work. hey butthead I meant to put sohc head but a dohc can fit with mods. anyways I need info on swapping a vtec SOHC head. no, it cant fit.. F block +H head.. nope. BTW:: I just purchased my 96 accord with a 2.2 non vtec and looking into swapping in a vtec head. But need more info on this. I was told it's been done and pretty easy but need a list of things I need to make this swap smooth. Any help would be great! Should I use a single cam or dual cam head? Thanks again not to sure what other F22 motor has vtec to tell you the truth.. but, on civic.. you need ECU, solioids(sp? ahh who cares), the cyl head, wiring harness, and vtec sticker. and yes, it is an easy prosess.. but if your not a motor head.. take it to a shop.. they can help.. Link to comment Share on other sites More sharing options...
VR17 Posted July 1, 2003 Share Posted July 1, 2003 fdghrfhdrstrferfdvb man sorry to say, but you have the weirdest name.. can you really remember that? oh and welcome to the board.. Link to comment Share on other sites More sharing options...
optional187 Posted July 1, 2003 Share Posted July 1, 2003 hey butthead I meant to put sohc head but a dohc can fit with mods. anyways I need info on swapping a vtec SOHC head. it won't fit with mods. i'd like to talk to the dumbass that told you it would. and..people...this post was started back on APRIL 22nd...yes, over two months ago. its dead. let the dead rest in pieces. Link to comment Share on other sites More sharing options...
VR17 Posted July 1, 2003 Share Posted July 1, 2003 this post was started back on APRIL 22nd...yes, over two months ago. its dead. let the dead rest in pieces. not my fault joecollins2 rasied the dead.. opps i forgot shinobi Link to comment Share on other sites More sharing options...
joecollins2 Posted July 2, 2003 Share Posted July 2, 2003 hey butthead I meant to put sohc head but a dohc can fit with mods. anyways I need info on swapping a vtec SOHC head. With mods? Yeah like another cam and everything you need for that is a light two hour mod ? Just get a DOHC motor. Obviously you don't realize.... Okay, picture a...... screw it. Get a DOHC BTW: Sorry butthead that was some sarcasm for that ass. Link to comment Share on other sites More sharing options...
joecollins2 Posted July 2, 2003 Share Posted July 2, 2003 Okay sorry. I didn't even look at the date of whe it began. I was just cruising through offering advice. I didn't mean to start an interstellar war over SOHC's and DOHC's. Did you see Honda's new TOHC? TRIPLE OVERHEAD CAM! Okay sorry. I'll stop. Link to comment Share on other sites More sharing options...
optional187 Posted July 2, 2003 Share Posted July 2, 2003 friend of mine has a quad cam oldsmobile. Link to comment Share on other sites More sharing options...
..SSR.. Posted July 6, 2003 Share Posted July 6, 2003 he swap doesn't give you that much more power. You would be better off just buying the whole F22B1. As for the DOCH VTEC swap, it will probably work. The head is a F20B. If you just want a DOHC non-VTEC, get a F20A head. Link to comment Share on other sites More sharing options...
VR17 Posted July 6, 2003 Share Posted July 6, 2003 he swap doesn't give you that much more power. You would be better off just buying the whole F22B1. As for the DOCH VTEC swap, it will probably work. The head is a F20B. If you just want a DOHC non-VTEC, get a F20A head. too bad you cant use F20C Link to comment Share on other sites More sharing options...
..SSR.. Posted July 6, 2003 Share Posted July 6, 2003 F + F = compatible. Link to comment Share on other sites More sharing options...
VR17 Posted July 6, 2003 Share Posted July 6, 2003 so... you can put a F20C S2000 head on F22B2 block (91accord) or have the F20C block and F22A SOHC?? not to meantion the RWD conversion you have to do..and the timing will be way off since DOHC meets SOHc.. not saying your wrong.. but i never crossed this shiet.. so gimme more proof.. Link to comment Share on other sites More sharing options...
..SSR.. Posted July 7, 2003 Share Posted July 7, 2003 Compatible means it can work. it will probably workNever said it will work. Link to comment Share on other sites More sharing options...
